Headlight question
I'm looking to wire up my headlights, but I have a question about the polarity of the headlamp bulb
I know that the upper prong of the bulb is for the low beams, what side of the 2 lower prongs is ground, and what side for high beams. Thanks |
Revitalizing a 6T C10
![]() Join Date: Aug 2017
Re: Headlight question
This is one I had saved from a while ago, colors might not be correct for our trucks, but the descriptions are....
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side. 350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs 20+ year long term project in process Lots of Rust, more memories... |
#3 | |
(Green) for ground for High beams Black for Ground.for ground for High beams Is that correct ? |
![]() Join Date: Mar 2006
On my 62 these are the wires I used to trigger relays:
Light brown/tan = low beam 12v Light Green = high beam 12v |
To add off of bhaps comment, this would be a good time to add headlight relays since you are in the process of wiring them. The improved lighting when running stock style headlights with the headlight relay is one of many advantages with this setup.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
