Old 06-16-2021, 12:24 PM   #1
kens65fb
Headlight question
I'm looking to wire up my headlights, but I have a question about the polarity of the headlamp bulb
I know that the upper prong of the bulb is for the low beams, what side of the 2 lower prongs is ground, and what side for high beams.
kens65fb is offline   Reply With Quote
Old 06-16-2021, 12:32 PM   #2
60short
Revitalizing a 6T C10
60short's Avatar
Re: Headlight question
This is one I had saved from a while ago, colors might not be correct for our trucks, but the descriptions are....
1960 C-10 Apache- "Rusty the Redneck Reject"
1/2 Ton short bed step side.
350 crate motor, 3 speed manual (floor shifted) MKII - Buddy Buckets and Glass Packs
20+ year long term project in process
Lots of Rust, more memories...
60short is offline   Reply With Quote
Old 06-16-2021, 12:37 PM   #3
kens65fb
I think the our trucks are (tan or brown) for low beams
(Green) for ground for High beams
Black for Ground.for ground for High beams
Is that correct ?
Old 06-16-2021, 03:18 PM   #4
kens65fb
Is that correct ?
Are these the correct colors?
Old 06-16-2021, 07:37 PM   #5
AcampoDave
AcampoDave's Avatar
Yes
AcampoDave is offline   Reply With Quote
Old 06-16-2021, 07:45 PM   #6
bhap
bhap's Avatar
On my 62 these are the wires I used to trigger relays:
Light brown/tan = low beam 12v
Light Green = high beam 12v
bhap is offline   Reply With Quote
Old 06-18-2021, 02:48 PM   #7
Southcity
Southcity's Avatar
To add off of bhaps comment, this would be a good time to add headlight relays since you are in the process of wiring them. The improved lighting when running stock style headlights with the headlight relay is one of many advantages with this setup.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
