Old 02-17-2022, 11:46 AM   #1
Bushman66
73-87 Spindles for discs on 66 C10 with Moog part numbers
All,
Ran across a YouTube channel by Rene Krause that demonstrated this swap. He listed the Part Numbers required, was wondering if anyone else has done this swap like this. With these parts, you can use your stock 66 upper and lower control arms, centerlink, and idler arm. Pitman arm will be a 71 as part of my P/S swap.
73-87 Spindles
73-87 Calipers
6 Lug Rotors from CPP etc
2 73-87 Lower Ball joints - Moog P/N K6136
2 73-87 Upper Ball joints - Moog P/N K6117T
66 Idler Arm - Moog P/N K14
2 60-66 OUTER Tie rods (will function as INNERS) - Moog P/N ES350L
2 73-87 OUTER Tie rods (will function as OUTERS) - Moog P/NES409RT
CPP Coupler - P/N CP4SC-SAR
Thoughts?
Bushman66 is offline   Reply With Quote
