Old 01-25-2023, 10:40 PM   #1
Riverstory
Riverstory's Avatar
Abandon 1966 E-brake cabling??
In a 1966 C10 panel (which is the same as a C10 shortbed), I'm finishing installation of a 454 with Hooker Headers and all seems good until I look at the e-brake cable routing. It runs directly where the exhaust pipe (post collector) needs to go.
Short of abandoning the e-brake system or having it rub across the pipe (neither is acceptable), what have y'all done to make this work? Thx
Riverstory is offline   Reply With Quote
Old 01-25-2023, 10:57 PM   #2
AcampoDave
AcampoDave's Avatar
Re: Abandon 1966 E-brake cabling??
Don't know if it will help, but the cables on my '66 were all shot so I converted it to the earlier style which uses the bolt in cross brace.
AcampoDave is offline   Reply With Quote
Old 01-26-2023, 04:16 PM   #3
Moarplease
Went a different route. Similar to the lokar emergency brake cables and connector cable, but less expensive. Can't remember the brand or components, but moved all the cables off to the side and mounted the Y inside the frame rail.
Adam
Moarplease is offline   Reply With Quote
Old 01-26-2023, 05:30 PM   #4
Riverstory
Riverstory's Avatar
Adam
Thanks Adam. Hopefully somebody here will see your installation and remember who made that system.
Old 01-26-2023, 05:34 PM   #5
Riverstory
Riverstory's Avatar
Adam -did you keep the original ebrake handle? Thx
Old 01-26-2023, 10:11 PM   #6
MT65
I made a system like Adam did, used lokar parts, didn’t know anyone else made stuff like that, lokar is about $100 for the cable system, I was able to use the stock ebrake mechanism in the cab, 65 c-10…just attached it to the lokar termination point
MT65 is offline   Reply With Quote
Old 01-27-2023, 02:22 AM   #7
Chevy nutcase
Chevy nutcase's Avatar
Just wondering if this lokar setup works a little better than factory or is it a night and day difference? Reason I ask is I replaced every brake component on my 66 c10 besides the e brake handle, adjusted them correctly and I still need to yank the handle uncomfortably hard to eek out 1 more click to keep my truck stationary on the slightest slope
Chevy nutcase is offline   Reply With Quote
Old 01-27-2023, 10:01 AM   #8
MT65
I can honestly say, I’m not sure, I have a t-56 transmission and just leave it in gear. I also have Wilwood discs on the rear and that would be different than a drum setup as well. I have used it occasionally, but never on any large incline.
I think the original factory setup gives you a leverage advantage at the crossmember where all the cables come together, whereas with just the cab mechanism might be lower in overall leverage coefficient…..
Old 01-28-2023, 10:56 AM   #9
72Mountaineer
72Mountaineer's Avatar
Rather watching this topic, I moved my e-brake on my 64 to a foot-type on the kick panel because of mounting a S10 tilt column, I'll need to reroute the cables also due to replacing the tranny crossmember for the TH350.
72Mountaineer is online now   Reply With Quote
Old 02-05-2023, 10:01 PM   #10
Backpayne
I did this same thing on my '64 and it worked great.
Backpayne is offline   Reply With Quote
