Help! What is this line?
Can someone ID this line and where it should be connected?
1985 C10 Has AC Looks to be some sort of AC vacuum control line or something. Comes out of firewall and routed towards driver side.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
![]() Join Date: Mar 2003
Re: Help! What is this line?
Goes to the vacuum ball, from the ball it goes to manifold vacuum with a check valve. That vacuum lines goes inside to the heater and AC controller for the hvac doors. Should be going not too far from where it is at the moment. The ball mounts to the evap box. I can see the feed line to the ball just below your thumb with the check valve
#3 | |
So if I were to get a new 'T' or something, Could I connect it somewhere in the red circle?
Where's your vacuum reservoir? That's where it's supposed to go, but yeah you can, but as soon as you shut the engine off nothing inside will operate vacuum wise
I will look today. I sold this truck a few years ago and just recently bought it back so I'll take a look.
BMW & ASE Master Certified
if you dont use a vacuum reservoir, it will be like my truck...., full throttle, a/c goes to floor
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
Bottom of a vacuum pot where the line goes. 2nd larger line goes to a manifold vacuum source. This one is next to the AC housing on the firewall. Some are spherical.
![]() Join Date: Oct 2014
Pics should help
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
Thanks for everyone's help. I started digging around and found the T-connection where this is supposed to be hooked up to. Comes from the vacuum reservoir right behind my jack on Driver's side fender.
