Old 06-01-2023, 08:52 AM   #1
LDO
LDO's Avatar
Help! What is this line?
Can someone ID this line and where it should be connected?
1985 C10
Has AC
Looks to be some sort of AC vacuum control line or something.
Comes out of firewall and routed towards driver side.
LDO is offline   Reply With Quote
Old 06-01-2023, 11:28 AM   #2
kwmech
Re: Help! What is this line?
Goes to the vacuum ball, from the ball it goes to manifold vacuum with a check valve. That vacuum lines goes inside to the heater and AC controller for the hvac doors. Should be going not too far from where it is at the moment. The ball mounts to the evap box. I can see the feed line to the ball just below your thumb with the check valve
Old 06-01-2023, 11:47 AM   #3
LDO
LDO's Avatar
Thank you!!
So if I were to get a new 'T' or something, Could I connect it somewhere in the red circle?
Old 06-01-2023, 01:26 PM   #4
kwmech
Where's your vacuum reservoir? That's where it's supposed to go, but yeah you can, but as soon as you shut the engine off nothing inside will operate vacuum wise
Old 06-01-2023, 01:48 PM   #5
LDO
LDO's Avatar
I will look today. I sold this truck a few years ago and just recently bought it back so I'll take a look.
Old 06-01-2023, 07:21 PM   #6
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
if you dont use a vacuum reservoir, it will be like my truck...., full throttle, a/c goes to floor one day I will put a reservoir in there
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-01-2023, 11:17 PM   #7
kwmech
Yep, there is that also that slipped from my mind
Old 06-02-2023, 07:59 AM   #8
Dead Parrot
Bottom of a vacuum pot where the line goes. 2nd larger line goes to a manifold vacuum source. This one is next to the AC housing on the firewall. Some are spherical.
Dead Parrot is offline   Reply With Quote
Old 06-02-2023, 10:56 AM   #9
TKCR
TKCR's Avatar
Pics should help
Old 06-02-2023, 07:29 PM   #10
LDO
LDO's Avatar
Thanks for everyone's help. I started digging around and found the T-connection where this is supposed to be hooked up to. Comes from the vacuum reservoir right behind my jack on Driver's side fender.
