The Older Generation
Installing Fender Emblems
I'm sure this has been covered before but this will be a refresher.... ![]() I ordered new fender emblems for the '72 GMC and they came with speed nuts. Since the fenders were already painted and installed on the truck I wasn't about to fight with the nuts, trying to screw them on the emblem studs behind the fender. I went to my local NAPA store and looked through the book for Tubular Nuts (Barrel Nuts) that would work. The first ones I found that were the right size were for a Chrysler and the NAPA part number was 665-1457. I told the parts man to go ahead and order them for me. They worked great and made easy work out of installing the emblems. The Tubular/Barrel Nuts were for 3/16" Stud Size, 7/32" Hole Size, with a Black Finish. I have included a picture for those who don't know what they look like. The picture also lists the manufacturers part numbers for GM & MoPar. The bold numbers are not the NAPA numbers. I jacked the pic off the internet. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-26-2008 at 08:38 PM. |
Parts and more parts
Re: Installing Fender Emblems
Screw the nuts, just get some 3M two side emblem foam adhesive and install the emblem without nuts. The 3M stuff will hold for a long time and if needed, it can be removed with a heat gun.
Tot Roddin'
Thanks for the info Leon!
File this one away for later.... ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Nice tip Leon!
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
#5 | |
![]() LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 10-26-2008 at 09:50 PM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Thanks for the tip ill have to use that on my blazer emblems.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
LAIDOUT
I glued mine on, no rattle and less likely to fall off or get stolen.
![]() Join Date: Oct 2001
Barrel nuts were widely used before the days of stick on mouldings and plates. As long as they are the right size they will not allow the emblem to be removed without access from the rear to squeeze the tabs with pliers.
'69 swb stepside in progress. '59 Corvette lifetime project |
Now that`s slick.Beats the tar out of unbolting the fender and jamming your arm up there to loosen those speednuts somewhere up there.
![]() Join Date: Dec 2013
Saving this for another day!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
Great Idea! Thank you,
I have been driving my truck for years without fender emblems because I did not want to pull the inner fenders. I decided last week that I can get one nut on so I added some silicone to the other side to hold them. I was planning on removing the inner fenders to get the second nut on for security. I am still going to remove the inner fenders just because I want to inspect under them.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
So Doc, do these fit flush and hold tight? The reason for asking is I've read that they leave a gap between the emblem and fender. If they do fit flush "I'm on it like a seagull on a dead fish". And thanks for the part number
No problem guys. Thanks. custom10nut: You can see how the fit is in the picture in post #1. That is one of the actual emblems I installed. These were aftermaket emblems so I'm not sure if they are made exactly like the originals or not. The only thing that sticks up is the small flange at the top of the tube nut. That is what keeps it from pushing all the way through the hole. The ones I used fit tight, in fact I had to clean the paint out of the holes in the sheet metal to be able to get them in.... If anyone has any problems with the install with these please post it in this thread... Thanks LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-03-2018 at 10:26 AM. |
Well, I'm off to NAPA in the morning
#15 |
I did this exact thing a little over a year ago. It works great. Nice tight fit too.
#16 | |
![]() ![]() ![]() Join Date: Oct 2015
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
#17 |
I did that on my Impala
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#18 |
Finally made it to NAPA today. $5 for a pkt of 16. Score!
#19 |
#20 |
Did you read the first post in this thread? LockDoc
#21 |
#22 |
#23 | |||
good gouge on the inserts LockDoc but that type of tension hardware can loosen in time and you only get one shot with the drill unless using existing holes.. this stuff is only .045" thick.. it's called booger tape and I've used it to install placards in the wheel wells and underwing of aircraft per Boeing spec.. yep, it's tough enough to hold an emblem on yer pickup ![]() Quote:
I started out with nothing - and I still have most of it |
#24 |
I had to order mine. These worked out great! Fit in the fender holes, snapped in place and emblems are on tight and flush.
![]() ![]() Thanks again Leon for doing the research. |
#25 | |
LockDoc
