Old 05-04-2024, 11:35 AM   #1
BanjoDude
Where to connect cigarette lighter socket light wire?
I ordered a replacement cigarette lighter socket for my 69 C20. The one that was in there was a cheap generic one that was shorted, and had no light. The one I ordered has a light in it. I took a larger fused wire straight to the battery for the supply, as I'm using a quick charger for my phone in it and didn't want to overload the single accessory circuit. Can someone point me to the proper place to connect the light wire?
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 05-04-2024, 11:53 AM   #2
dmjlambert
dmjlambert's Avatar
Re: Where to connect cigarette lighter socket light wire?
I suggest PNL LTS fuse connector, that way it will switch and dim with the other instrument cluster and dash lights.
Old 05-04-2024, 12:23 PM   #3
BanjoDude
This is great. Thank you! Do you know if the original had a light?
Old 05-04-2024, 12:51 PM   #4
BanjoDude
Old 05-04-2024, 01:20 PM   #5
Getter-Done
Getter-Done's Avatar
Yes the one without the light was standard and the lighted one was an option.
Here is a link with the Part #
Link: https://67-72chevytrucks.com/vboard/...d.php?t=847810
The early bird gets the worm,
84 Chevy K-20
Getter-Done is online now   Reply With Quote
Old 05-04-2024, 01:44 PM   #6
Rust_never_sleeps
Rust_never_sleeps's Avatar
Post #8 might prove illuminating:
https://67-72chevytrucks.com/vboard/...d.php?t=318487
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 05-04-2024, 04:08 PM   #7
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have the piggyback light attachment to my Cigar Lighter. I put a red filter on it from an Autometer gauge. Looks neat at night. Oddly the fancy light is still on, but my Cigar Plug socket has no power. Need to troubleshoot that in near future.
The GPS is the main customer.
I stab the terminal into IGN Unfused on the fuse box. I put a 10@ fuse inline between the terminal and the socket. I have had the Cigar Lighter line short out and burn up insulation on other wires it was bundled up with, so now I use a fuse.
Old 05-04-2024, 06:06 PM   #8
jabborabbo
jabborabbo's Avatar
Originally Posted by '68orangesunshine View Post
I stab the terminal into ign unfused on the fuse box. I put a 10@ fuse inline between the terminal and the socket. I have had the cigar lighter line short out and burn up insulation on other wires it was bundled up with, so now i use a fuse.
this ^^^^^^^^^^^^^
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
