05-24-2004, 12:51 AM | #1 |
anyone built their own lowering blocks?
i have a 4/4 suspension drop on my 67 and the back is just sitting too high for my taste, so i want to lower it some more. all i have right now is a 4" drop coil. i am taking shop class at high school right now and i am not doing anything, so i was wondering if any of you guys have built 2" lowering blocks. if so, can you give me instructions or pictures.
thanks, 67pro-street |
05-24-2004, 01:05 AM | #2 |
It's a catastrophic success.
I used 4" C channel, cut two holes and welded 3/4' pipe where the U bolts go though then capped, basicly a box with two reinforced holes in it.
05-24-2004, 09:01 AM | #3 |
TX firefighter has some good pics of lowering blocks he done. Just take some good steel square tubing or some good angle and drill holes in it for the u-bolts. Get longer u-bolts and just bolt them in.
05-24-2004, 11:00 AM | #4 |
71 DELUX
Yup, I made my own...but I use 1/2" aluminum bar, and made four for each side, so that I could play around with the 1/2" - 2" drop range out back. Came in handy as 2" was too much (along with my 3" springs), and I've currently decided that I like two plates. This is the way the DJM drop kit packaged and sold, but with 4 -1" blocks. If you go with 2", you will need longer U-bolts.
05-24-2004, 11:27 AM | #5 |
I made a couple once out of solid stock, if you go that route you better have something good to cut it with :p
05-24-2004, 09:38 PM | #6 |
I made some out of old trailing arms cut the ends off i still have them acutally i had a hard time finding 3 inch longer u bolts. but as i recall ed at mother truckers sells them i had bought springs since then so i didnt need blocks anymore. if you want to see pics let me know .
05-25-2004, 08:23 AM | #7 | |
Watch out for your cornhole !
05-25-2004, 09:14 AM | #8 |
Happy to be here
You cab build them, but why? They are so cheap to buy from PEP Boys that it's not really worth your time...
05-25-2004, 09:42 AM | #9 | |
05-25-2004, 11:06 AM | #10 | |
Happy to be here
05-24-2004, 11:44 PM | #11 |
Your UncleBen
I have a set of lowering blocks that I would sell if you want them. Brand new never used or installed. I believe it comes with the U-bolts with the blocks. Haven't looked at em in so long I cant remember. But I think they did.
lata CHRIS
68 C10 shortbed -- Street/Strip |
05-25-2004, 08:24 PM | #12 |
Your UncleBen
But the ones from Autozone will. A buddy of mine lowered the rear of his 68 CST with the same blocks that I have. I am going Bags and not going to use them.
I wrode in it after he cut the front springs one coil a put the blocks on the rear and it didnt ride bad at all. I was expecting much worse. All that spring travel that these trucks have I guess. lata CHRIS
68 C10 shortbed -- Street/Strip Last edited by SweetandLong68; 05-25-2004 at 08:28 PM. |
05-25-2004, 09:27 PM | #13 |
Struggling Artist
Blocks
I built mine out of 2" solid stock and drilled 13/16" holes on a lathe for the "U" bolts.g[/IMG]
69 1/2 ton lwb lowrider 90 C-1500 2wd 08 2500 HD 4WD 94 Grand Cherokee 49 Cadillac sedan |
05-25-2004, 09:29 PM | #14 |
Struggling Artist
Darn pics didnt work
05-25-2004, 09:29 PM | #15 |
Struggling Artist
05-26-2004, 12:10 AM | #16 |
Your UncleBen
Those pics look pretty close to what we did bad 69.
lata CHRIS
05-26-2004, 12:16 AM | #17 |
thanks for the help fellas. i have one more question. how much longer should my new U bolts be. should i just take out the old ones, measure them, and then add two inches? I was thinking of taking 2" x2" steel tubing and then cutting two holes in it and reinforcing them with round tubing and then capping off the ends. Do you think that would be strong enough.
05-26-2004, 08:00 AM | #18 |
Here's what I did. Just tubing that I capped the ends on.
My local parts store don't sell blocks that are even close to working. They are intended for leaf springs and come with 4 small diameter U bolts and the blocks have locating pins on them.
05-26-2004, 02:23 PM | #19 |
anyone have any pics of this with leaf spring trucks? Mine is leaf with the square spring "u-bolts" and i can't find crap that works at local parts places.
05-26-2004, 04:01 PM | #20 | |
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
05-26-2004, 02:15 PM | #21 |
Now the others dig........
So....I'm guessing you sit a jack under the trailing arm and lower it after you break loose the ubolts??? Or how do you do it???
Sorry to butt in.....but it is a question that needs to be asked.....just minor details I guess...
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
05-26-2004, 09:10 PM | #22 |
PROJECT 7DEUCE
I built mine just as tx did and they worked pretty good...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
