Sound-proofing 69 Stepside
Anyone got any great ideas on quieting down my ride?
It only came with a flimsy little floor mat and there's no sound treatment on ceiling, doors, hood, firewall or floor. What can I do here?
69 Stepside. Rebuilt 327, HT 350 tranny, Holley carb, Edelbrook intake; Flowmaster dual 2.5-inch exhaust. |
![]() Join Date: Feb 2003
pix
We'll have to see pix of the whole truck before we can decide...
English Chevy Owner
A lot of people seem to reccomend Dynamat for soundproofing, you can do floors, inside the doors, bulkhead etc with it. Getting some carpet down will help as well, but hey, it's a truck not a BMW, it was designed to do a job not to be a luxury car, just get a louder exhaust and listen to the engine or a big sound system!
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
There are some other threads on here that also recommend either a product called "Brown Bread", or another product called "Raamat". I think they are very compariable to Dynamat, "brown bread" claims to be better than Dynamat, and a hell of a lot cheaper!!
www.raamaudio.com http://www.b-quiet.com/brownbread.html Hope this helps a little.
In addition to the areas for sound material installation, do the back wall behind the gas tank. If you go with a head liner and soft door panels, this helps, also.
Jim |
Keep On Truckin'
Here's what I did with a Dynamat knockoff from E-bay. I don't know the results yet since the truck isn't done.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
Mocwon,
Nice job! Jim |
Insert funny comment.
![]() Join Date: Dec 1999
Mocwon, how much square feet did it take to cover your cab? I see brown bread in 10.5 sq ft and then 35 sq ft.
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com Last edited by lock; 07-12-2004 at 11:02 AM. |
product name?
Mocwon:
What is this stuff called? How much did it cost?
Bucket of Bolts
This is the project that never ends, yes it goes on and on my friend.... |
Keep On Truckin'
The stuff I bought off Ebay last year was a Dynamat knockoff but I don't remember the name. It was $100 + $25 shipping for 100 sq.ft. I have enough left to do the inside of the doors. The only thing I didn't like about it is that it required heat to apply and it took quite a while to install it.
This stuff looks like a better deal and it is pressure sensative: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38638&item=7909508447&rd=1&ssPageName=WDVW
Keep On Truckin'
Apparently, I need help with the Ebay item link above...
![]() Join Date: Apr 2000
Not to steal the thread but has anyone tried to insulate between the two layers of the roof?
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#15 | |
Left Foot Functioning
Good question. I'm running an ABS headliner that holds 4 speakers and covers the whole headliner area. I drilled a 3/4" hole to run the wires through, and while banging around up there, I noticed how hollow it sounded and thought I should do something about it. I had used the canned expanded foam called Great Stuff on several projects around the house, so I had some handy. I shot some through that hole, then got a longer tube and pushed it up through the openings at the back of the cab into the front, middle and sides. It held a couple of cans of the minimal-expanding foam. They also have a version that expands a lot more, but I was afraid it might ooze out somewhere I didn't want it. It made a big difference, and cost about 12 bucks. Now if the floors and doors were that easy...SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
#16 |
I bought the Brown Bread recently but have yet to install it. From the checking I did it looked like the best stuff. Do a search for Brown Bread and you'll find som more info.
1971 Chevy Cheyenne 383/350 LWB 2wd Built to use, and look good. ![]() |
#17 |
I thought of using the expanding foam but was afraid it would bow the roof.
#18 |
The oddest Todd around
I must have it all backwards. I took it all out to save weight.
It's not a 1/4 screamer, but it'll blow the doors off of the ricers at the green light. Now I just need to lose a hunder pounds off of my fat a$$. |
