Old 10-17-2004, 02:38 PM   #1
c10chevy69
c10chevy69's Avatar
Auto tranny trouble
Need a little help with my trans. My 350 auto will not shift into 3rd when the selector is in drive but if I shift manually it will. Checked linkage and tightened it up and fluid is full. What gives? Thanks.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 10-17-2004, 07:34 PM   #2
rage'nrat638
rage'nrat638's Avatar
check to see that the vacuum hose from the intake to the vacuum mod..on the trans. is hooked.....
if it is pull the hose off at the modulator on the trans...and see if fluid come's out.....if so the modulator is bad ....replace it....
rage'nrat638 is offline   Reply With Quote
Old 10-18-2004, 08:44 PM   #3
c10chevy69
c10chevy69's Avatar
Got it working
Thanks for the help. I got busy last night and didn't see your post until later on. I stopped at Autozone and picked one up just in case I needed it ($9.95 if anyone should ask). I got under there and hunted around for it and found the line disconnected. Plugged it back in and third gear is back! I think it is about time to put a new piece of rubber hose on that dude it doesn't stay on very well. Once again Rage'nrat thank you very much.
