10-17-2004, 10:37 PM | #1 |
door hinges
ok guys ive got a question. im trying to get my hinge pins out of my door hinges so i can install new ones but im having a hard time trying to knock them out. is there an easy way in doing this. i ground the pointed end off flush with the rest of the hinge but still no movement in the pin when i hit it. any help would be appreciated
1972 chevy long bed. Currently under construction!! Bagged, 383/700r4. |
10-18-2004, 12:06 AM | #2 |
I can sum it up in one word...Pneumatics. Buy yourself a cheap (or good) air hammer/chisel & they usually come w/ a few chisels.
Hit it w/ that & be patient. It'll just sit there hammering, hammering, hammering, & then all of a sudden it starts to move. WD-40 & about 2-3 days time helps too. You'll need another small rod (like a center punch for driving finishing nails flush) b/c the chisel will be too bid to chase the hinge pin the entire way.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
10-18-2004, 12:47 AM | #3 |
Sisyphus was my mentor!
when I did mine I had to beat the krap outa them with a 5lb hammer. I added heat from a propane torch & that made them go easier.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-18-2004, 08:22 AM | #4 |
Good advice, heat is our friend!!!!! Also sound advice penetrating oil and some time.
I found Kroil works better than wd-40. As I am a farmer I deal with rust on equipment all the time. Good luck with hinge repair, Mike |
10-18-2004, 09:50 AM | #5 |
We put them in a vise and heat them with a torch and knock the pins out with a long carriage bolt.
Rest in Peace Ed. Thanks for all the good times. |
10-18-2004, 10:44 AM | #6 |
TOTY 2006
I had to use a press to get my pins out. Tried using a hammer and punch, just broke the punch....
