Old 02-27-2005, 01:19 AM   #1
benscool1
benscool1's Avatar
Burb fuel tank?
Will a 72 burb fuel tank work in a 73 Chevy pickup chassis? I know you can do the mod w/73-91 blazer tanks, and I think 67-72 blazer/suburban tanks were the same. I know no matter which you use you will have to make a few brackets but thats no problem. I'm just wondering if the tank will fit since I already have one lying around.
Ben
84 C10 Silverado
14 Silverado Z71
benscool1 is offline   Reply With Quote
Old 02-27-2005, 01:52 AM   #2
Russell
Professional Grade
Russell's Avatar
If it is a longbed, yes, shortbed, I don't believe so. I am putting an EFI burban tank onto my K25 chassis, and other than having to move the usual three brackets, I've not run into any problems
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 02-27-2005, 01:55 AM   #3
benscool1
benscool1's Avatar
Exactly what am I going to have to do to make it fit then? Right now my truck is setup for dual tanks but I'd have to run all the wiring and new hoses and stuff and I'd rather just bypass all that, or maybe just stick with a single tank but my bed still has holes for dual tannks. What would my options be for a filler if I used a burb tank?
Ben
84 C10 Silverado
14 Silverado Z71
Old 02-27-2005, 02:06 AM   #4
Russell
Professional Grade
Russell's Avatar
If you are not running EFI, why not run two tanks on the one side, just cut out the bed side in the back for the burb tank filler neck, and put it in place of the door you cut out from the other side? Either that or just make a couple patch panels and fill them in
I plan to cut the door out of the front and move it to the back, with the spare metal from the back filling the front.
Old 02-27-2005, 02:11 AM   #5
benscool1
benscool1's Avatar
Yeah, but I don't wanna have 2 doors on one side of the bed. I was thinkin maybe a hole in the floor, but that would probably require a lot of fabrication. I've seen some people also put the filler behind the taillight, and put the taillight on a hinge. Has anyone done either of these in our trucks?
Ben
84 C10 Silverado
14 Silverado Z71
Old 02-27-2005, 02:25 AM   #6
Russell
Professional Grade
Russell's Avatar
I'd be quite difficult...
I'd just find a decent bed, cut the patch you need out, put it in on one side, then swap door for patch for the other part
