Old 03-30-2005, 12:10 AM   #1
rage'nrat638
rage'nrat638's Avatar
Unhappy 69's th400 won't shift out of 1st...wtf...
well just put a new intake on it...holley carb,,,, o yea lifters.....
airrade spacer......run's excellent.....just won't go
th400 stuck in first gear.....now what?
rage'nrat638 is offline   Reply With Quote
Old 03-30-2005, 12:17 AM   #2
70c10
67-72 Addict!
70c10's Avatar
Is the vacuum for the tranny hooked up to the carb?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-30-2005, 12:19 AM   #3
Josh
He's got mean nasty FANGS!
Josh's Avatar
Could either be the vac modulator or the governor, thats what i'd check first...
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 03-30-2005, 12:21 AM   #4
avejoe
Custer had a plan too.
avejoe's Avatar
Once my truck would not shift out of first. I had knocked the vac line loose.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 03-30-2005, 02:39 AM   #5
ChebyCheyenne
ChebyCheyenne's Avatar
Will the trans shift through the gears if you run through them manually (L1, L2, D) instead of starting just in Drive?
Truck #1:
1972 Chevrolet K20 Cheyenne Custom Camper
SB400, TH400, NP205
Truck #2
1967 Chevrolet C10 Custom Sport Truck
327 small journal, TH400
ChebyCheyenne is offline   Reply With Quote
Old 03-30-2005, 09:42 AM   #6
72gord
Never enough time!!
72gord's Avatar
That would be my guess...vacuum line off at one end or the other, should shift up manually though.
72gord is offline   Reply With Quote
Old 03-30-2005, 12:22 PM   #7
Russell
Professional Grade
Russell's Avatar
Mine did that too, cept if you really pushed it,then it'd shift. I just knocked the modulator line off enough that it looked like it was on, but it wasn't :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-30-2005, 05:55 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep, if you shift it manually, and it shifts, then your modulator is either not hooked up...not getting proper vac...or inoperative.
