Old 04-15-2005, 12:18 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Smile e-brake cables and what to do with them...
...after a lift? What did you do?
I was thinking of moving the bracket rearward or moving it to below the bottom frame rail. This is the bracket at the front of the rear springs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 04-15-2005, 01:48 PM   #2
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Neither of my lifted trucks have there emergency cables hooked up. Hoping to get around to it this summer but not sure which is the easyiest or the best way to do it?
Thanx for reminding me about them!
-Later
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 04-15-2005, 02:26 PM   #3
ryanroo
ryanroo's Avatar
after an 8 inch lift i just gas axed them, didn't work to start with, but in retrospect i really wish i had attempted to make them work instead of chopping them off. oh youth...
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-15-2005, 03:01 PM   #4
GMC71k20
ya i need a solution too, mine rub against my leafs =( i was thinking of the drivetrain brake but its way to expensive
GMC71k20 is offline   Reply With Quote
Old 04-15-2005, 03:33 PM   #5
Hoods69BadBowTie
Chevys Kick A$$
Yeah, I checked out the drivetrain brake too and it did seem pretty spendy.
-Later
-LATER
Old 04-15-2005, 07:43 PM   #6
454_72_4X4
454_72_4X4's Avatar
I just removed the entire system.
I worked a couple extra hours to save the cables on the rearend when I swapped in the corp 14 and then they turned out to be to short to reach anyway.
Made more room at the kickpanel for speakers and I'm gonna use a hydro lock. Just gotta get around to putting it on...
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-15-2005, 08:15 PM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My problem is I have my GMC registered for general use w/ the DMV, which means an annual state inspection and the e-brakes have to work. Something I did notice my 71 w/ eaton seems to have longer cables from the rear end than the 70 GMC w/ dana60. I also have a dana60 from a 71 C20 and i'm going to see if those cables are any longer. I let you know. Oh yea, I only lifted the rear of the GMC 3" and the e-brake cable was rubbing and tight against the front spring bracket for the rear springs. The chevy has a 71 chassis.
Old 04-15-2005, 11:37 PM   #8
kwmech
I moved the brackets back when I installed a 14 bolt. Then I had a different intermediate cable made
Old 04-17-2005, 01:01 AM   #9
72k5
72k5's Avatar
I cut a V out of the center of the old bracket, and bent it to close the V - so it angled the cable down more. Then I welded up the cut and relocated the bracket to the bottom of the frame rail. I cut the cable that runs in a U, and added a piece to it using crimp-on cable ferrules. Works great.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 04-17-2005, 03:33 AM   #10
4x4Poet
Good method...and cheap. When I finally lift my K20, if the e-brake rear housings won't remain unstressed when "stretching" with the suspension droop, I'll probably splurge for a new, custom e-brake cable with longer rear housings and rear loop. I think the cable that's on there now has seen its better days.
Inline tube makes custom e-brake cables for a pretty penny. A collectible penny, that is.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 04-17-2005, 07:13 AM   #11
I never had an issue with the e-brake/4" lift(that I was aware of).It`s been a while since I`ve had a lifted truck,though,and I was younger and dumber.I always wanted to go to a hydraulic line-loc like tow trucks use.Does the inspection allow extensions/splicing?
Old 04-19-2005, 12:09 AM   #12
72k5
72k5's Avatar
I had no issues either until I put the 14 bolt in. The longest cables I could find were coming up short, so I had to relocate the brackets. You're right, the OE 1/2 ton setup will work with quite a bit of lift.
Hydraulic line locks are good for holding the brakes while winching, but not useful as a parking brake since the fluid pressure will eventually leak off. They also are only as good as your hydraulic system, so they are of no use as an "emergency" brake. I've found that the parking brake usually has more braking than the 4 tires have traction, so I just lock in 4WD for winching.
