Old 08-08-2005, 10:51 AM   #1
fade94
fade94's Avatar
Question BATT gauge wiring
How can I wire my BATT gauge to work with the new style one wire alt I have?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 08-08-2005, 07:05 PM   #2
fade94
fade94's Avatar
ttt
Old 08-08-2005, 08:32 PM   #3
JimKshortstep4x4
Talking
If your gauge is the original ammeter then it should work as is as long as the power wire from the battery is the same. If you changed the power wire, it still can be made to work.
Jim
Old 08-08-2005, 09:39 PM   #4
fade94
fade94's Avatar
Can someone describe or draw how it needs to be wired? With colors?
Old 08-10-2005, 08:54 AM   #5
fade94
fade94's Avatar
Anyone??
Old 08-19-2005, 09:29 AM   #6
fade94
fade94's Avatar
N E 1?
Old 08-19-2005, 10:01 AM   #7
jhow66
jhow66's Avatar
Did it worK before? If so should work now with no change. If it didn't check the 2 four amp fuses at each corner of radiator support.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-19-2005, 11:16 AM   #8
JimKshortstep4x4
I suspect that in wiring up the one alternator, the original power feed wire has been by passed. The original ammeter works off of very low power, (it senses the voltage drop caused by the wire resistance in the short distance from one side of the radiator to the other). If the one wire off of the alternator goes directly to the battery then the charge reading for the gauge has been eliminated. There is a way to hook up the ammeter but it would be helpful to know what was done and the size of the wire used.
Jim
Old 08-19-2005, 11:41 AM   #9
fade94
fade94's Avatar
I don't have any past info on the truck. The alt had been upgraded before I got it and I don't know if the gauge worked or not. I just need to know what wire needs to go where to get it to work.
Old 08-19-2005, 02:02 PM   #10
john
member #16
john's Avatar
Heres a diagram that shows the wires with the 4 amp fuses. As mentioned before if your alternator wiring is different than the diagram (direct to batt) it will need to be wired like diagram to work. John
john is offline   Reply With Quote
