Drive shaft length?
I am putting my 71 to a short frame. What is the drive shaft length for a short tail auto trans? I currently have a TH350, but also have a TH400 that I want to put in. Will the same shaft work for both trans (I know the yoke is different).?
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
try www.tciauto.com for trans lenghts. i think you will find the short 350t(6" tail), is 11/16" shorter than a short tail 400T,& thats enough that the same lenght shaft wont work with a 1 pcs shaft. on a 2 pc shaft , with a slipyolk in the middle, i have spilt the difference tween the trans & center slip......& swapped a 3spd stick for a 400T, & also the other way without problems. crazyL
http://community.webshots.com/user/hotrodhorn |
its all about the +6 inches
4 foot 10 inches on a SWB with a one piece shaft a TH350 with a small block mounted in the correct location.
