Old 09-23-2005, 08:41 PM   #1
slammed64
Finally
finally found one. the unicorn!!! at least to me it was. a 72 5 bolt rear end. got it the other day for $200 bucks canadian. that is like, $180 U.S.D. it was a smokin deal. i've got it in the garage, now time to rebuild it. new bearings, drums,shoes,spring kit, and some fresh oil. can't wait to actually put it on and install rear bags, put new 5 spokes on and finally set it on the ground and see her stance. will let you know soon enough how she looks.
64 chev 1/2 ton lwb fleet slammed
86 chev Z28 IROC camaro (vacation car)
73 VW super beetle (wife's project)
02 VW Golf 2.0L (good on gas car)
04 FORD F-350 CREW CAB diesel (work truck)
slammed64 is offline   Reply With Quote
Old 09-24-2005, 01:15 AM   #2
Frizzle Fry
Frizzle Fry's Avatar
Right on
Frizzle Fry is offline   Reply With Quote
Old 09-24-2005, 01:43 AM   #3
a squarecan
Glad to hear you found what you were looking for. That just so happens to be the exact thing I have my eye out for now my self. A 67-72 5 lug rear end with decent gearing.
Keith
a squarecan is offline   Reply With Quote
Old 09-24-2005, 02:39 AM   #4
Frizzle Fry
I got lucky when the '69 stepside I bought had already been upgraded to 5 lug all around. The I swapped all that stuff onto my '69 Burb.
Old 09-24-2005, 10:58 AM   #5
El Caballo
Let me ask you guys, do the 67-72 rearends use springs as well or are they leafs? Is that why it was the unicorn?
El Caballo is offline   Reply With Quote
Old 09-24-2005, 11:44 AM   #6
a squarecan
The 67-72 do also use coil springs, so no need for an modifaction. That is why people tend to sway away from the later 73-87 (91 burb) rear ends is because they only offered leaf springs in those years. If you are baggin it and having to build all new brackets, no big deal. If you are looking for a bolt in replacement you have another thing coming.
Keith
Old 09-24-2005, 12:11 PM   #7
El Caballo
That is what I thought and figuredI would try and find one if it existed as well. I can weld, but if I don't have to do the pinion angle and all that, why should I?
The quest begins because I am going to put a 73-87 front end on my '62.
Old 09-26-2005, 06:53 PM   #8
62ChevyStep
62ChevyStep's Avatar
[QUOTE=El Caballo]That is what I thought and figuredI would try and find one if it existed as well. I can weld, but if I don't have to do the pinion angle and all that, why should I?
I have a 10 bolt/ 5 lug rear end (not sure of the gear ratio) in my 62' right now that will be coming out, it is already set up for pinion angle and rear coils etc. and will be replaced with a 72' 12 bolt (3.73) posi rear I found in the local wrecking yard. Gonna do rear Wilwood oversized disk brakes. I wont need the 10 bolt rear if your interested, your 173.5 miles NE of me on the otherside of Amarillo, TX.
________________________
62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4
08' Chevrolet Silverado CrewCab
05'Toyota Tacoma Prerunner SR5
62ChevyStep is offline   Reply With Quote
Old 09-26-2005, 10:12 PM   #9
El Caballo
[QUOTE=62ChevyStep]
How much? PM me with the answer and thank you very much.
Old 09-27-2005, 12:12 AM   #10
62ChevyStep
Talking
First let me say you are welcome. Now the price, I know you said to PM but I don't think "Free" requires a PM..... Yes I said free, when I pull it (I will be checking soon to see what I need to have this 12 Bolt ready to go in) when I pull the 10 Bolt out, I can contact you and you can come at your convienance and pick it up, I will store it in my shop for you until you either come get it or contact me and tell me you don't want it, at which time I will find a new home for it. I am not in the market to make money off of anyone, if I can help/bless you so be it, it was on the truck when I received it and if I can help someone else out fullfill their dream in someway great. I am also not in to collecting or storing extra parts, I acquire, utilize, and thin out parts that will be of no use to me.
It is already set up, it is a straight swap in, I am using a TH350 tranny, it is currently on my 62' Step that I drive almost daily, it will be complete from brake drum to brake drum.
Old 09-27-2005, 02:10 AM   #11
Slammed66
Needs a Big Block
Slammed66's Avatar
Gord. I have some Bad news. so far Ive only been able to locate 1 drum that was worth a ****, Ill keep diggin and keep ya posted
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 09-27-2005, 01:27 PM   #12
El Caballo
Wow, thanks again! That is very generous and I appreciate it very much. Please check your PM for my contact information.
Ted
Old 09-25-2005, 01:26 PM   #13
slammed64
El Caballo. the 71 and 72 rearends use coils. that is why they are so desired, cause they can bolt right on. they are getting harder and harder to find. for me it was a 6 month wait trying to find one for the right price. i've seen lots on the board, but shipping to canada, no thanks. around here they are $500 at most places, and most parts trucks people want way to much for. My brother-in-law found me one for $150 but he is 5 hours away, and no way to get it here. time,fuel prices, etc. so to me, that is why i call it the unicorn, but that really isn't right either, a unicorn is a fabled creature that does not exsist. i got one now, so i'll call it a sasquach now. you know it exsists, it's just about getting your hands on one. your best bet is to find a 71 or 72 parts truck with disks on the front, then you have a perfect donor.
Old 09-25-2005, 01:31 PM   #14
Slammed66
Needs a Big Block
Slammed66's Avatar
Way cool gord, now get to work, Ill lets you know about some drums tommarow!
Now get to work.
1964 Short box
1972 K10
Old 09-25-2005, 01:32 PM   #15
slammed64
also El Caballo, one more thing, you mentioned a 73-87 front end, you don't need the whole front end, just the a-arms,disks,brake parts etc., spindles,and tie rods and hardware. much easier than changing the whole front end. good luck
Old 09-25-2005, 01:35 PM   #16
slammed64
thanks matt, that would help out alot. when i go looking for replacement parts for this rearend, what am i looking for. i know, drum,shoes,spring kit for brakes, what else, bearings??? what are they called? and of course change the oil.
Old 09-25-2005, 03:45 PM   #17
El Caballo
Gord, agreed, just easier to say I'm getting the whole front end since really that is what is happening. I can get a clip for $250 US, and I will begin my seach for a yeti in Tejas.
Mmmm, Tim Horton's...
Old 09-25-2005, 05:45 PM   #18
slammed64
who told you about Tim Horton's?????? that is supposed to be our little secret. or have you actually smuggled some out of our country. you know you can get arrested at the border for that. are you makin' fun of me-us. if you are, good joke eh!!!!!
Old 09-25-2005, 06:39 PM   #19
El Caballo
While I live in Texas now, I spent a good many years in both Maine and Washington, I know my doughnuts.
Old 09-25-2005, 08:49 PM   #20
slammed64
sweet man, so you probably know about the stan makita's reference in wayne's world. your practically canadian, living that close.
Old 09-25-2005, 11:43 PM   #21
Slammed66
Needs a Big Block
Slammed66's Avatar
Hahah , Chad and I stopped at stan makita's , somewhere in bc at like 1 in the morn ,on the idaho trip. Umm on my diff I did the axle bearings? I cant remeber what they are called the ones in the ends of the axle tubes, and new seals, new lube and posi addative, all new brake hard ware and showes wheels cylinders etc.
1964 Short box
1972 K10
Old 09-26-2005, 12:30 AM   #22
jasonrmorrow
Matt/Gord did i hear you right when you said your brother-in-law found you a 71-72 diff for $1505 hours away from brooks ?? Would that be in Red Deer ?? I'm gonna need one eventually for my rig. Thanks
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 09-26-2005, 09:48 PM   #23
slammed64
jason, i'm only about 2 1/2 hours from reddeer as the crow flies. and only about 1 1/2 hours from calgary, that's crusin'. i still might get my bro-in-law to get it for me, doesn't hurt to have a spare. later
