Old 12-20-2005, 11:02 PM   #1
dennislbrooks
dennislbrooks's Avatar
leveling
short of letting air out of the tires or throwing concrete blocks in the bed, how can I lower the rear about 1-2 inches?
dennislbrooks is offline   Reply With Quote
Old 12-20-2005, 11:39 PM   #2
laynlow77
Re: leveling
just get some shackles. they are about 50 bucks. you can lower either 1 or 2 inches with them
laynlow77 is offline   Reply With Quote
Old 12-20-2005, 11:42 PM   #3
bigarmzz
bigarmzz's Avatar
Re: leveling
take out one of your helper or overload springs...all it'd cost ya is the time and maybe another center bolt
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 12-21-2005, 12:54 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: leveling
Looks like he is asking about a 67 rear suspension. Blocks should get what you want....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-21-2005, 01:21 AM   #5
SCOTI
SCOTI's Avatar
Re: leveling
Shackles for a truck/leaf suspension or blocks for a truck/coil suspension.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-21-2005, 07:54 AM   #6
dennislbrooks
Re: leveling
ok, it has coils, so the blocks go between the axle and the trailing arm? thanks
Old 12-21-2005, 08:24 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: leveling
Here's a picture of a set I built.
Knowing you, you will build a tricker looking set. I built these at work when I worked for the Post Office. We didn't have too much fabrication stuff to work with in that shop. It's 2x3 thick wall tubing that I capped on the ends with plate. The u-bolts came from a local truck spring shop. I took in a stock one and told them to build me a pair 2 inches longer.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-21-2005, 09:24 AM   #8
dennislbrooks
Re: leveling
Thanks to all --you gave me a path that leads somewhere. TXF, I believe all that I require if I can retain the ubolt threads is a full nut on them. I will look to see how much I can get with the OEM u-bolts. Then after I waste that time --go after longer ones.
