Welding gas for MIG?
I'm getting ready to put my cab back together, and was wondering what welding gas I need for my MIG. I've heard Argon, but I've also heard Argon/Co2. Which is it? Thanks!
1964 Chevy Short Fleet: Tornado 1972 Chevy C10: Fast Orange Secondaries Wide Open |
Project92 SWB stepside
Re: Welding gas for MIG?
yes 75/25 argon 75/c02 25
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
![]() Join Date: Feb 2004
agree with phantom dually, I use 100% argon on my TIG for both steel and aluminum but I use the mix for my MIG. CO2 is less expensive than argon and has superior heat conductivity. unless you are welding 4130 --- 100%
C02 can be used however I have not tried it. |
Old Skool Club
![]() Join Date: Jun 2001
Is Stargon, the commercial name for the Argon/Co2 mix? Just curious....it's what I have in my tank with my MIG welder....which I have yet to learn to use. Shame, shame, shame.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Thanks for the help guys! The local dealer said he has what I need, so all I need to do is sign the gas contract and get to work on putting my cab back together.
Stargon sounds like the name for a gas company. C25 is what the mix is generally known as
C10 or C25 are used in our industry. C10 being the cheaper and used with solid wire on 65-80k psi steel. Metal building manufacturing.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
Got Horsepower?
it can also be called Blueshield. the gas company here Norco calls it #7 75argon/25co2 and #9 is 90argon/10co2
2001 Dodge 2500 Cummins, 4 inch lift, 35" Toyo MT's on Ultra wheels, P-Pump Conversion, AFE intake, Fass, 5 inch exhaust, Pyro,Boost,and Fuel pressure guages, and a whole bunch of other stuff "The Money Pit" SOLD-71 Chevy C10 long bed- 2/4 drop-- 350,th400, Edelbrock performer RPM intake,Edelbrock 600 CFM carb,Crower 240 cam,port and polish,Dynomax headers,HEI ignition,dual 2.5 inch exhaust with Flowmaster 50 series mufflers |
