Old 02-18-2006, 09:36 PM   #1
GMFamlee
GMFamlee's Avatar
Electrical delimma...Ack!
I am not real good with electrical problems. The right front signal won't work on my '71; the bulb won't light. Following the usual troubleshooting manuals, I replaced the bulb...nothing. I replaced the assembly, nothing. Now, my left flashers blink very slowly and my emergency flashers don't at all. Any ideas short of the whole wiring harness? I don't think that's it anyway. Help!!
GMFamlee
1971 Cheyenne 20 LWB 400BB
1996 GMC Sierra SL SWB 4X4 ExtCab
2001 Honda Civic EX (Mamma's Ride)
"He stops talking only long enough to switch feet"
GMFamlee is offline   Reply With Quote
Old 02-18-2006, 09:41 PM   #2
GMFamlee
GMFamlee's Avatar
Re: Electrical delimma...Ack!
Would the switch keep one bulb from working?
GMFamlee
Old 02-18-2006, 10:50 PM   #3
cdowns
cdowns's Avatar
first thing i do with light problems is take the ground wires apart and clean the connections
Old 02-18-2006, 11:28 PM   #4
GMFamlee
GMFamlee's Avatar
If I'm looking at all the flashers and stuff, looks like a looong weekend. Thanks. I did that with the r/f already.
GMFamlee
Old 02-19-2006, 03:49 AM   #5
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
get a multimeter or a test light and check for juice at the prong connector with either the 4 ways or right turn signal on. If you're 4 ways don't work I'd check all the way around on the back side as well. It sounds like a switch problem to me.
WRMZ71 is offline   Reply With Quote
Old 02-19-2006, 06:27 AM   #6
Sweet72
Sweet72's Avatar
I'm with cdowns on this one. Bad ground. There should be a ground on the rad core support from the light assy. pigtail, check this first. http://www.geocities.com/chevroletc1070/v8engcomp.html
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 02-19-2006, 09:29 AM   #7
truckdude239
truckdude239's Avatar
my left front wasn't working but every thing esle was flashers worked park light didn't i had a bad switch
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-20-2006, 08:52 PM   #8
GMFamlee
GMFamlee's Avatar
Update: My emergency flashers and left blinkers are working normally, but the rear sidemarkers come on with the lights, but they don't flash. My left front sidemarker works right, and the right front sidemarker works like the right front turn signal -- that is not at all.
GMFamlee
