Old 03-26-2006, 12:52 AM   #1
71swb4x4
71swb4x4's Avatar
A little progress on my suspension, 2wd bags
After a long winter of waiting for warmer weather (no garage heater) I have finally started on my suspension. Today I figured out where I am going to put my front tank and valves. We really don't have much room on these Blazers/Jimmy's to put the tanks and valves. Up front I am going to run a two gallon tank with my valves mounted to it. The tank will be mounted a couple inches behind the front bumper, but in front of the first crossmember.
Here's a picture.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-26-2006, 12:55 AM   #2
71swb4x4
71swb4x4's Avatar
Re: A little progress on my suspension, 2wd bags
The valves do not hang below the frame at all. I will probably mount a piece of aluminum under the tank and valves to try to keep some dirt and water away, but this is going to be a fair weather vehicle anyway.
In the rear I am going to run a three gallon tank, it will be just outside the frame rail on the passengers side. The front and rear tank will be tied together with 1/2 air line. Both tanks will be fed by a York compressor.
I hope to have all of this done by mid May. I only get a few hours a week in the garage, so this will be a long project.
Old 03-26-2006, 09:42 AM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Interseting place to put the set-up, a couple of ?'s, does it interfear with
the bumper? does it interfear with the rad deflector? who makes the tank?
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 03-26-2006, 09:45 AM   #4
71swb4x4
71swb4x4's Avatar
It doesn't interfere with either. It's about two inches behind the bumper, and the top fitting will be about 1/2" from the radiator deflector. The tank is two gallon, do you want the physical measurements?
Old 03-26-2006, 09:48 AM   #5
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Yeppers, I hope to start on mine next year, still trying to get a 68 clip
at the moment, I will be keeping tabs on your progress, and thanks
Old 03-30-2006, 07:49 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Very creative place to mount the set-up....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
