Old 03-29-2006, 12:48 AM   #1
mySAVIOReigns
Active Member
mySAVIOReigns's Avatar
Post New Seat not budging
Hello, I think this is my first topic here, can't remember I've got an 85 C10 that I've been using as a daily driver and workin on for a while, and I got a new seat today out of a 78ish Chevy. My question is, the seat won't budge forward. (in other words, I can't get behind the seat). It should fold forward right? I can't figure out how to get it forward. Any tips? Thanks
Stephen
Here's some pics: (it's the bench, the buckets are retarted and SOLD!)
http://pg.photos.yahoo.com/ph/mysavi.../ph//my_photos
mySAVIOReigns is offline   Reply With Quote
Old 03-29-2006, 06:57 AM   #2
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: New Seat not budging
Im not shure what year chevrolet did this but there are some bench seats that have a release lever at the base of the back on both sides and they both have to be held up at the same time in order to get the seat back to fold forward.
Look to see if theres one on each side of your seat if so then you will need to have someone help you.
If not then maybe someone bolted the thing so it wouldn't fold fwd.
or it could just be rusted to the point that it won't fold fwd.
Maybe it would be easier to remove it from the truck and flip it over to see why it won't fold fwd.
That's all i can think of for now but it cant be too many things so it shouldn't be that hard to figure out what the problem is.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 03-29-2006, 10:05 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
I'm pretty sure that folding seats were optional on earlier trucks. I have found several in the junkyard that did not flip forward.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-29-2006, 01:03 PM   #4
mySAVIOReigns
Active Member
Well that sucks lol. It's not rusted, the "frame" of the seat is all new, the foam, and the springs too. I'll check to see about that lever, cause I did see something that wasn't on my old one, that might be it.
Old 03-29-2006, 01:25 PM   #5
Eyegore
What Hump?
Eyegore's Avatar
My sons 78 camper special has a lever as 78 stepper said, I used it just the other day.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-29-2006, 05:31 PM   #6
Russell
Professional Grade
Russell's Avatar
My 80 and 77 both flip, but neither my 74, 76 or 79 flipped forwards. The last few trucks were base model, while the 80 / 77 are both top trim model trucks.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-29-2006, 09:29 PM   #7
89 crew
If the seat is out of a crew cab or suburban it won't tilt. It will have 2 bolts per side, and most of the time they are covered with material. If you use the truck with the seat all the way back you can remove the top bolt and it will work in a regular cab. It might lean back a bit more than you are used to.
89 crew is offline   Reply With Quote
