My truck is slanted! ARGH!
I posted this already in another part of the forum, and realized that this section was here, so well....now here it is in the correct section
![]() I have an '81 C-10. The truck rides fine however when you look at it from the front, its obvious that the front end of the truck on the driver's side is sitting lower than the passenger's side. Its not really noticable while riding inside though, only when viewing the truck from the front and the issue only seems to be on the front; the rear of the truck appears level. Unfortunately I just moved and don't have my digital camera here with me yet, so I can't post pictures yet. Any suggestions on the problem or solution? Also, does anyone have any step by step pictures of a drop job? -Justin |
Re: My truck is slanted! ARGH!
problem - collapsed coil spring
solution - replace coil spring |
HA HA HA HA! Straight to the point. I like it.
Thanks, I'll check it out |
you could always get yourself a fat girlfriend to sit in the passenger seat and even things out
Outlandish Trends - FL
You've got the infamous "chevy lean". Lot of the newer body style trucks have this problem, even from the factory. Like Shane said, it's most likely one of your coils. Although I wouldn't recommend it, there are companies that make coil limiters that fix this. I think it's a urethane piece that fits in between the coils to limit its travel. Don't know how safe they would be though. Have you isolated the problem to the front for sure?
-Bret 67 short-fleet sold! |
![]() Join Date: Dec 2001
Or better yet, two regular-sized girlfriends.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
better yet still, replace them with lowered springs and just get a girl ...
with big ol' bosoms! ![]() Last edited by Shane; 07-13-2006 at 10:33 PM. |
the poly spacers space up the low side to even it out. and yes, its the typical chevy lean.
Active Member
Good excuse to bag it.
