Old 03-08-2007, 11:26 PM   #1
Low84
Low84's Avatar
Single Headlight "Euro" Conversion
Lets see if somebody can help me. I have a single headlight (total of two) which are currently sealed beam. Has anyone converted over to headlights that covert it into a bulb, I think they are called "Euro" headlights.
I need the number of the bulb, if anyone has it please let me know.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 03-08-2007, 11:37 PM   #2
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Single Headlight "Euro" Conversion
most of them take an H4 bulb, I had em on my first gen S10 and they worked well
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-08-2007, 11:47 PM   #3
Low84
Low84's Avatar
S10 is a smaller headlight, you think its still the same for my large single ("200mm" I believe headlight)?
Here is the deal, I want to put some HID's on my truck but I got to change to bulb headlights. I don't want to make a purchase only to find out I won't be able to install HID's.
Old 03-09-2007, 12:03 AM   #4
AspecialZ
Street Rod Restoration
AspecialZ's Avatar
I want to say 1150, but I think thats wrong, these are what you are refering to, just search a place like ebay for them. they are alot cheaper than "autozone/Advance"
I thought I had a picture of them on my 74.
Follow me on Instagram @ hot_rod_shop
AspecialZ is offline   Reply With Quote
Old 03-09-2007, 12:06 AM   #5
Low84
Low84's Avatar
YEAH, THOSE ARE THEM!
I'll go do a search right now see what I can come up with.
Old 03-09-2007, 02:51 AM   #6
Low84
Low84's Avatar
Allright, I did the search. All I came up with is that the headlight bulb used for the dual headlight chevy's is the H4. That's for the 4x6 1/2
However my headlights are the 7x6. And I can't find out what bulbs those use.
Old 03-09-2007, 12:05 AM   #7
AspecialZ
AspecialZ's Avatar
eurolite is the company, I have delt with them for years, good product, but be prepared to modify the back of the headlight buckets.
Old 03-09-2007, 03:10 AM   #8
84slopwaggin
84slopwaggin's Avatar
I thought LMC sold these, as well. They even sell the correct wiring harness to make the transition less painful.
84slopwaggin is offline   Reply With Quote
Old 03-09-2007, 03:33 AM   #9
Low84
Low84's Avatar
Yup, but they don't say what bulbs they use. I need to know what bulb it is, so I can figure out if I can install HID's on the truck.
Old 03-09-2007, 07:37 AM   #10
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: Single Headlight "Euro" Conversion
LMC does sell the ones your looking for but like you said they dont list what lamp is being used.
Call them and ask
I just bought the complete set form them for my '87 and they use a 9006 lamp but thats a dual headlight system.
BTW the units LMC sells are of a high quality and fit really well
I had a set in a S10 like the one in the pic above and they were some elcheapo brand and they didnt fit the light bucket real well and the trim ring that holds them in was loose so i had to wrap the light assy. with some tape to compensate for that.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 03-09-2007, 12:55 PM   #11
bmartin9122
bmartin9122's Avatar
HID's are not generally recommended for a single reflector, dual-element set-up like we have. You will lose your high beams. The only work-around I see is to install auxillary halogen running/fog lights to serve as the "high-beams". Obviously, some rewiring is going to have to take place.
79 GMC Sierra Grande K15
--PPG paint code 62608 Sunburst Orange Metallic (WA802K)
--Gentex auto-dimming rearview mirror model K31
--Carriage Works billet grille model 40071
--Go Industries 2.5" tubular stainless headache rack
--Sylvania Silverstar sealed headlights model H6024ST
--Texas Saddlebags center console model 101
--Brown's Welding class IV V-5 pipe bumper
--Ramsey RE8000 winch
--33" tires
bmartin9122 is offline   Reply With Quote
Old 03-10-2007, 12:47 AM   #12
Low84
Low84's Avatar
Call them and ask
Good looking out guys, thanks for the help/advice.
Old 03-09-2007, 10:53 AM   #13
Zoomad75
K5Camper
Zoomad75's Avatar
The light bulb for the H4 conversion housings are 9003's for the single lamp systems. 9006's as stated above are for dual lamp setups.
Rob Z.
1975 K5 350/465/205/D44/12b 4" lift on 35's- RIP
1991 K5 8.1L/NV4500/241/D44/14b FWC Camper
Zoomad75 is offline   Reply With Quote
Old 03-10-2007, 01:46 AM   #14
AspecialZ
AspecialZ's Avatar
here you go!
http://cgi.ebay.com/ebaymotors/7-ROU...spagenameZWDVW
Old 03-10-2007, 01:47 AM   #15
AspecialZ
AspecialZ's Avatar
Originally Posted by AspecialZ View Post
the same giy has different styles in his store, pretty cheap too
Old 03-11-2007, 12:00 AM   #16
Pyrotechnic
Pyrotechnic's Avatar
So the LMC lights are pretty good quality ?
How do they compare in light output with the typical sealed beam ? How about with a set of silverstar bulbs ? If this will get me some more light output then I will definetly make the investment.
Pyrotechnic is offline   Reply With Quote
Old 03-11-2007, 08:35 AM   #17
see ten
WTB this ad
see ten's Avatar
H4 indicates the pattern on the plug in if I'm not mistaken (either that or the bulbs pattern where it mates to the housing). Either way,H4 is what I have in the replacement lights on both my Jeep TJ and my 72K10 (both are round lights). So apparently being H4 has nothing to do with the shape of the reflector. As far as HID goes, you can buy them with a HI beam but they are not DOT legal. It has to do with the bulbs not being shielded to prevent blinding oncoming traffic. There is a member named subtle71 who has installed them but apparently he doesn't want to share any inormation about them. I have PMed him several times and he will not reply. I guess he's either very busy or wants to be the only member running HID . You can go to Ebay motors and do a search for HID conversion and find quite a few kits. I have no idea which ones are worth buying.
see ten is offline   Reply With Quote
Old 03-11-2007, 07:53 PM   #18
AspecialZ
AspecialZ's Avatar
You are correct, "HID" refers to the Bulb housing or "lamp", The type of bulb is dependant on your application. What you want to look for are lights that a "diamondbacks" these light housings already have the placement of the "reflector cap" this allows the light to bounce off a mirror to the back of the housing, which is lined with different style mirror pieces reflecting the light forward again. Yes, silverstar is a good brand and you will pay usually in the 20-30 dollar range for them. I have had them in my S-10 for 3 years and have no problems. They do project the lights out very well and you can see great. If you have a question I would be happy to help you out. thanks...and good luck.
Old 03-17-2007, 09:09 PM   #19
BaddBusa2005
BaddBusa2005's Avatar
the H4 fits numerous different housings. I tried them on my 81 4 eye'd truck. I had to cnahnge too much wiing to make it riht so I left the High beam conversion and went back to sealed beams on the lows
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 03-17-2007, 11:23 PM   #20
84Custom
Junior Member
84Custom's Avatar
I got these from US auto parts a few years ago.The H4 bulb works without any rewiring and my high beams work fine.The light bucket does require some mod. and the retaining rings work with them.Hope this helps sorry no pics of them in the truck,I started the rebuild before I got my camera.They look good and work good too.
Scott C.
84 Custom Deluxe(under Construction)
87 Buick Grand National
91 Gmc Sierra daily driver
84Custom is offline   Reply With Quote
Old 03-18-2007, 12:08 AM   #21
BaddBusa2005
Yeah the h4 will work fine on a 2 headlight truck, they will not work (right)on a 4 headlight truck.
