Old 04-13-2007, 06:38 PM   #1
dave2953
Dave's not here, man
dave2953's Avatar
Schrader Valves
I've been toying with the idea of putting bags in the rear of my truck; I couldn't afford a complete setup so I'd have to use schrader valves as a means of inflating. Is it a bad idea to run a setup like this temporarily? Thanks for the help; I'm not well versed in the ways of bags.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 04-13-2007, 08:49 PM   #2
SCOTI
SCOTI's Avatar
Re: Schrader Valves
I ran 2 schrader valves on my 68 for almost 2yrs.
The only problem I had was occasionally when I tried to air the bags up in the wee morning hours (in the dark ), I would bend the valve & it wouldn't let me put air in. It didn't happen a lot, but it was inconvenient when it did. I started keeping a few extra valves just in case.
Once I started using my trailer more often, I went ahead & got a comp & tanks to make life easier. I also always kept a 5gal portable air tank as an emergency air source..... but never needed it.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-14-2007, 12:13 PM   #3
72 cheyenne pdx
72 cheyenne pdx's Avatar
Re: Schrader Valves
I am not sure if it was a factory option or if the PO made it, but my FIL had air shocks on his 69 El Camino that had Schrader valves that mounted right under the tailgate. He said it was great to have because, whenever he had to carry a load in the "caruck", he would roll into a gas station and put air into the shocks to put it back to stock height. I would assume that you would be able to do the same thing with bags as long as you kept the bags independent.
Good luck on the set up.
72 cheyenne pdx is offline   Reply With Quote
Old 04-14-2007, 01:18 PM   #4
SCOTI
SCOTI's Avatar
Re: Schrader Valves
Yep.... That's how I used mine but the air went to bags vs. air-shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-14-2007, 08:05 PM   #5
dave2953
dave2953's Avatar
Re: Schrader Valves
Thanks for the replies. I was looking at bags and suicidedoors. Are the Slam Specialties better than the Firestones or any others. I see that they are a little more expensive, but I don't really know the difference between them all. Thanks again!
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 04-14-2007, 09:55 PM   #6
jlaird
jlaird's Avatar
Re: Schrader Valves
Popular opinion would say, yes they are. Some of the attributes that the Slam bags have are in internal bumstop and its said they "balloon" (expand horizontally) less. They have a very good reputation in the lowered scene. Get them!!! With that said, firestones are tried and true....
jlaird is offline   Reply With Quote
Old 04-14-2007, 11:07 PM   #7
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Schrader Valves
I'm gonna run Slams & manual valves (Kinda half on the cheap)
I will run 6 valves (from the hardware store) one tank, & the front bag brackets from suicide doors
I already have the tank, some left over air-line, & maybe a couple of the valves
I plan to build my rear brackets, so that is just less money i have to spend
I think I should have around $450 in that setup, so it's not too bad $$$ wise
Aslo, I bagged a little trailer with 2 valves, a air-tank (just like one from wal-mart) & some firestone bags
The 6 valves go in this order: One valve per bag, with one in between the 2 to keep the air from going side to side
1st valve is air inlet, which T's off to the 2nd valve, which T's to the 3rd valve
So lets say you want to air the front up, you open up one & two and to dump the front you open 2 & 3
I also plan to run pressure 2 regulators (one for front, one for rear)
Hope this helps, & doesn't confuse
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 04-16-2007, 02:14 AM   #8
Rollie396
someday it will be done!
Rollie396's Avatar
Re: Schrader Valves
imho when you decide to complete the system go with 8 valves...saving cash at the expense of safety doesn't work.BTW I use shraeders on the helper springs on my welding rig and they work out great.I ran them out the back bumper so they double as the license plate mount.
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore.
'80 LWB 2wd beater
'67 GMC long fleet (cab donor)
'66 long step (parked till it's turn comes around)
'65 short step (parts truck that will donate it's bed and possibly frame to the '66)
'06 Grand Prix wife's car (she hardly lets me touch it)
my pics
Rollie396 is offline   Reply With Quote
