Old 06-27-2007, 06:16 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
BADBOW's new engine!!!
GM crate ZZ4. Sequence number 1232!!
Found it on Craigslist!!! The motor was taken out of a totalled Vette. I purchased the ZZ4 from the second engine owner who never installed it. I went through it.
You can see the refresh and buildup on this slide show.
http://rides.webshots.com/slideshow/559613073URLEuc
The engine and motor are back in the truck. I'll post those pictures as another topic.
Additional parts:
New RPM Air Gap Intake
New gaskets and seals
New water pump-reverse rotation for serpentine belt system
High temp paint
New ceramic coated inside and out Chevelle headers
Part Number: 24502609
Engine type: Chevy small-block V-8
Displacement (cu in): 350
Bore x stroke (in)cf6 : 4.00 x 3.48
Block (P/N 10105123): Cast iron with 4-bolt main caps
Crankshaft (P/N 12556307): Forged steel
Connecting rods (P/N 10108688): Powdered metal steel
Pistons (P/N 10159436): High-silicon aluminum with offset pins
Camshaft type (P/N 10185071): Steel hydraulic roller
Camshaft lift (in): .474 intake / .510 exhaust
Camshaft duration (@.050 in): 208'c1 intake / 221'c1 exhaust
Cylinder heads (P/N 12556463): Aluminum; 58cc chambers
Valve size (in): 1.94 intake / 1.50 exhaust
Compression ratio: 10:1
Rocker arms (P/N 10089648): Stamped steel
Rocker arm ratio: 1.5:1
Recommended fuel: 92 octane
Ignition timing: 10'c1 BTDC @ 800 rpm, cf0 32'c1 total @ 4000 rpm with vacuum advance disconnected
Maximum rpm: 5800
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 06-27-2007, 07:31 AM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: BADBOW's new engine!!!
wish i had that engine for the chevelle .
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 06-27-2007, 09:20 AM   #3
cochino12
It followed me home?
cochino12's Avatar
sweeet! I had a zz4 in my 85 and loved it.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-27-2007, 12:51 PM   #4
augie
Waiting for Paul to Open Safe
augie's Avatar
gchemist that's a sweet motor and I'm sure it will fit perfectly into BADBOW. I have always been a fan of your truck and BADBOW's webpage. Nice find.
Norwood Survivor
http://squarebody.net
augie is offline   Reply With Quote
Old 06-27-2007, 11:19 PM   #5
gchemist
gchemist's Avatar
My brother and I did a lot of work in one day. The hardest part was drilling the frame for the custom transmission crossmember. I also converted from a one bolt tranny mount to a two bolt type. The preloaded mount should put more power through the wheels. The next hardest modification is trying to route the dual ram air box intakes for the 91 grill. Once its running, it's on for a truck gathering at the track in Temple!!!
