is using a propane heater inside a garage safe?
we bought a mr.heater today scense its starting to get cold and ran it about all day..the garage is only a two car garage
is it safe |
Chevy Truck Addict
![]() Join Date: Aug 2006
Re: is using a propane heater inside a garage safe?
I used a propane heater in my garage... You shouldn't leave it unattended, make sure it never gets too close to flammable materials and you will want to make sure the building is well ventilated or open some doors for fresh air occaisonally. The propane heat will suck the oxygen out of the air and could cause you to get light-headed or, even worse, lose consciousness. To make a long story short, they're safe as long as you're careful.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
'71 chevy s.bed/s.side
![]() Join Date: Mar 2005
Be careful, they suck up alot of oxygen. You might want to google it and look at the pros & cons. They heat great, but they do emit a bit of an odor.
STILL PLAYS WITH CARS...AND TRUCKS!! Parents! Be good to your kids...they get to choose your nursing home! 250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive! |
i used them for many years without problems// the utmost care must be used in storing your cleaners paints and other explosive stuff and respect the heater a brain fart can cost you a garage or a life
you do have fully charged fire extinguishers in the garage?? i made an anti tipover stand for mine dont point it at the vehicles gastank is a good idea
![]() Join Date: Jun 2003
I used to heat a cabin with a propane heater. I kept the flame right, blew out the burner each season before lighting the first time. Even though the cabin was leaky I cracked a window open for the fresh air. I was using a stationary propane tank with a copper line ran to a shut of valve in the cabin. My supplier requires the tank to be at least 15' from the building. Like the previous post stated move all flamables out of the garage. I still have some Deareborn propane heaters that I will be using in my shop, if I ever get my doors on that is.
Parts and more parts
Think about your garage size and consider the amount of FREE AIR space that you have. I use a 35,000 BTU forced air propane heater in my garage, but I only run it for about 30 minutes and then shut it down and use a couple 500 watt quartz lights to keep the temp comfortable. My garage is 40' X 40' with 12' ceilings, so my free air space is very large. I also have alot of insulation, so the 30 minutes brings the temp up to about 65 degrees and it is comfortable for me.
Official Site Guitar Shredder
i run my propane heater for about 45 mins...it works well for my garage ( i think its a 30x30...it gets the temp to aout 60 and works fine ...i usally work with asweat shirt on anyways, so im comfy
~Rest In Peace~
all good from my garage no problems ohh expect when the beer fridge is empty
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex Last edited by fastwillie 696969; 12-09-2007 at 08:11 PM. |
ok thanks
no we dont have a fire extuisnger...but we have it away from eveything so it should be fine |
#10 | |
Luv the Crewcabs
Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
i laugh when i see the tragedy stories about idiots who went out in boats with out life preservers
pick up a fire extinguisher even if you decide NOT to use the propane heater. it's just makes good sense to have one around, regardless.
Chevy Truck Addict
That's great advice about the fire extinguishers. It's a good idea to have them in the house, in the garage and one in the truck also... You never know.
oh there will deffentley be one on the truck..we just went and got the one out of our boat just incase
and we cleared some more stuff out so we should be good |
