Old 12-14-2007, 05:40 AM   #1
SUBURBULANCE
LT1 conversion help for 1970 suburban
I am just finishing putting a LT1 motor with a 4L60E transimission in my 1970 suburban high top ambulance. I need to find a converter to switch the electronic pulse transmision into a cable drive so I can use my original speedometer. doing a little research i came up with Cable X which would definitely do the trick but i was hoping to spend less than $300 to do so. I was wondering if anyone had one laying around or had another recomendation for me
SUBURBULANCE is offline   Reply With Quote
Old 12-14-2007, 09:01 AM   #2
GMCPerson
Junior Member
Re: LT1 conversion help for 1970 suburban
If I remember correctly, Jagsthatrun have these for sale. I got mine from the local speedo repair shop. Good Luck - Paul
GMCPerson is offline   Reply With Quote
Old 12-26-2007, 05:36 PM   #3
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
You can also buy a tailshaft that has provisions for both speedo hookups on it.
low'n slow is offline   Reply With Quote
Old 01-01-2008, 11:20 AM   #4
Wootdog
Wootdog's Avatar
Like the previous person stated you can get a different tailshaft. I wish I would have went that route. I have the Cable X setup and it works ok. But you have to make sure on the tailshaft there is a special fitting. That is what the Cable X sensor picks up. The excitation of the moving tailshaft. It is a press on fitting.
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
