Old 05-18-2008, 08:42 AM   #1
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Ball Joints!!
Does anyone know if it is really that hard to change out ball joints? I am puting new drop spindles on my truck and was told to change the ball joints as well. Is there not a special tool that I need to change these out?
jgrisafi is offline   Reply With Quote
Old 05-18-2008, 12:48 PM   #2
oldspowered67C10
Re: Ball Joints!!
The uppers just bolt in, no special tools required. The lowers are pressed in and do require some kind of tool. You can hammer out the old ones sometimes but youll most likely have to use some kind of press to install the new ones. You can either rent or buy a ball joint press(kinda like a really beefy c-clamp) or you can remove the lower arm and have them pressed in at the machine shop.
oldspowered67C10 is offline   Reply With Quote
Old 05-18-2008, 03:00 PM   #3
LONGHAIR
Re: Ball Joints!!
The uppers only "bolt-in" after you cut/drill out the rivets. Unless they have already been changed, the factory used rivets, but they go back together with bolts.
The lowers are a press situation either way.
LONGHAIR is offline   Reply With Quote
Old 05-18-2008, 06:46 PM   #4
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
Re: Ball Joints!!
In the Haynes Manual under ball joints it shows how to make a removal tool out of a bolt, socket and nut, I'm about to try it in the next couple of days I'll let you know how it comes out.
79gmcsierragrande is offline   Reply With Quote
Old 05-18-2008, 11:36 PM   #5
jlaird
jlaird's Avatar
Re: Ball Joints!!
don't forget that if you have an auto parts store near you, they probably have a free loan program.
jlaird is offline   Reply With Quote
Old 05-20-2008, 01:53 PM   #6
HotRodYJ
HotRodYJ's Avatar
Re: Ball Joints!!
I have the BJ tool and a press at homke now, but years ago we used to use knock out the lower's with a big hammer, then use the weight of the car to press in the new lower BJ using a floor jack and a block of wood. Basically just lack it up and the weight of the car will do the "pressing". Now I use the proper tool, but it always worked great.
If your just changing spindles, the upper BJ is all that should need to be changed assuming your lowers are still in good shape. As said before, on the uippers you grind out the old rivets and bolt a new BJ back in. I put dropped spindles on my 71 and the instruactions said I would have to use a 73-87 upper BJ and outer TRE's. My upper BJ actual fit perfectly and I didn't have to shange it, but the TRE did have to change.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
