09-04-2008, 08:56 PM | #1 |
86 steering box?
will an 86 power steering box work on my 64. i was told on here that the steering column wouldn't so will the box easily hook up to another column?
09-04-2008, 11:35 PM | #2 |
Re: 86 steering box?
You need this kit. http://www.classicparts.com/1960-66-...ctinfo/76-979/ It makes it alot easier to install the box. You do have to shorten the steering column. I put in a tilt from a van and now have a split shaft. The lower shaft is from a 70's truck. Just cut the factory end off and used a DD adn 36 spline u joint.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 09-04-2008 at 11:37 PM. |
09-05-2008, 12:55 PM | #3 |
if your gonna use the 86 box, why not just go ahead and use the 86 column?
Then you won't have to worry about cutting shafts and using u-joints. Just collapse the 86 column by drilling out the two plastic retainers and move to the desired length. The hardest part about the newer column is modifying the column/bracket under the dash. All it takes is knocking off the 3 or 4 weld-nuts and moving them to match the holes on your factory bracket. check this site out: http://persh.org/Pickup/steering.htm |
09-05-2008, 04:53 PM | #4 |
Even if the shifter is on the floor it would have to be a stick shift but the ignition is on the column as well, which you don't want.
this was a quote from someone on here. do they know what they are talking about? is $150 a good deal on a '86 power steering box and tilt column? Last edited by dhughins; 09-05-2008 at 05:46 PM. |
09-05-2008, 05:42 PM | #5 |
You should not have any problem with the steering box. They are a 605 box and fit from a variety of years. These pics are not a pretty way but it is an easy way. Every thing is a bolt up on the shaft. Use a collapsible intermediate shaft. Use the rag joint off the 86.
09-05-2008, 10:09 PM | #6 | |
09-05-2008, 06:25 PM | #7 |
Acually the steering box in my picture is from an 86 sub.. And I am using a van column without the key in the ignition. I was going to try and use an 88 column but it was hard to get the high beam switch rod to clear the bracket so I back to basics.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
09-05-2008, 11:33 PM | #8 |
The Van column dose not have the key in the column. I think they started that in 1981. No need for dremeling anything off or filling anything. That is what the difference is. No biggie.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 09-05-2008 at 11:34 PM. |
