Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-13-2008, 10:48 PM   #1
Slowmotion
Help picking a bumpstick
I have a 61 short step with a 396 bored to 402. 8.5 to 9.0 compr, performer rpm intake, and large oval heads. I'm also running a turbo 400 trans torque converter is just over stock with 4.11 gears for now. Any suggestions on a good camshaft for this combo?
Slowmotion is offline   Reply With Quote
Old 11-14-2008, 01:42 AM   #2
Super73
Super73's Avatar
Re: Help picking a bumpstick
What diameter and length headers?
What size carb? Vacum secondaries?
What are you willing to spin the motor too?
How about valve springs and lifters?
Is this a strip only deal or street strip?
With a slightly bigger than stock stall, I assume bottom end TQ is important to you?
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-15-2008, 12:37 AM   #3
Slowmotion
Headers are Flowtech 31132 full length headers. Carb is an Edlebrock 750. Valvesprings are stock, but can always be changed, and I planned on usind Rhodes lifters. Yes bottom end torque is important to me. I had planned on building a light strip heavy street truck, now I just want to shut a few friends up.
Old 11-15-2008, 08:58 PM   #4
Super73
Super73's Avatar
With out making a motor profile, I would guess something around a:
230/230 @ .050 with .550ish lift on a 106 ICL with a 110 LSA.
Old 11-16-2008, 12:54 AM   #5
Slowmotion
Smile Re: Help picking a bumpstick
Old 11-17-2008, 02:59 PM   #6
6D9
With the tight converter you are not gonna want to much duration or its gonna kill your low/mid range torque. If you plan on a hyd flat tappet I would run this one. Will work great with your low comp ratio and tight converter.
Comp XE268......268/280 adv.....224/230 at .050....515/520 lift....110 lsa.
6D9 is offline   Reply With Quote
Old 11-18-2008, 10:25 PM   #7
Slowmotion
Thanks for the suggestion. Comp Cams recomended xe274, so I was trying to decide between that one and the Voodoo vdbc268. Both are close to your suggestion, and almost exactly what Super 73 suggested.
