Active Member
![]() Join Date: Aug 2008
Header Solution
I was having problems tring to find full length headers with 1 3/4 primary tube that would not hang below the framerails with sbc. So I got with a local header shop and made a proto-type set and are now ready for production. We use heavy wall 14 gage steel tubing (.083) thick, 3/8" thick laser cut flanges, 14 gage tubing for our collectors and take great pride in our finish work. All of our headers are fully welded around each primary tube on both sides of the flange. This gives the header a more "finished" appearance, reduces areas for rust to start and adds superior strength. We hand finish each port and machine the face of the flange flat to fully seat to the head as well as insuring there is no reduction in flow. We offer all flange options but have found the ball/socket connection to be the best all-a-round connection. They offer a leak-free seal without the use of a gasket, allow for some movement and adjustability during the install and they are much more reliable than a flat flange. Primary tube sizes are available in 1 5/8" or 1 3/4", depending on the power/torque specs of the engine. They are $550.00 bare and $865.00 CHROMEX ceramic coating plus shipping. Here are some pictures and I will post more when I get them back from coating.
Last edited by Jokers69; 07-11-2010 at 03:13 PM. Reason: ceramic coating price increase |
Active Member
Re: Header Solution
More pictures
Like a Rock!
Re: Header Solution
Nice job! They look like they are modeled after Hedman. Will the finished product have the tubes dented in at the bolt locations or is this just because it's a prototype?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Active Member
Re: Header Solution
They will be clearenced on 1 3/4 and very little on 1 5/8
![]() Join Date: Feb 2001
Re: Header Solution
How are they getting to the plugs?
Active Member
Re: Header Solution
You have great plug access.You can run straight boot spark plug wires on all cylinders but #6 it requires a 90 degree boot.
![]() Join Date: Jan 2008
Re: Header Solution
Those are very nice looking headers.I've built several sets over the years.They look like they're easy access to the plugs,and I like the 14gu. tubes,and the 3/8" flanges are nice. Seems to be a very fair price for the quality of the product.These headers coated will most likely last the life of the truck.
Active Member
Re: Header Solution
Thanks, They are very well built and no problems with them ever hitting the ground.
#9 | |
spirit rider66
![]() Join Date: Oct 2008
Location: pahrump, nevada, in the bowels of the Mojave desert
Re: Header Solution
Larry ![]()
:Chevy: If you don't run your own life,, some one else will. ![]() ![]() ![]() |
Re: Header Solution
Will these still tuck level with the frame rail with a porterbuilt dropmember?
Active Member
Re: Header Solution
That I don't know. I have never tried to install one with that dropmember. I will see if I can find a local truck to test fit.
#12 | |
Re: Header Solution
Sweet job on the headers. ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
The LuvShack Garage
Re: Header Solution
Nice
Active Member
Re: Header Solution
These will not work on manual transmission with factory clutch linkage. The headers tubes will not fit around the clutch linkage.
#15 |
Active Member
Re: Header Solution
Here they are coated.
#16 |
![]() Join Date: Nov 2008
Re: Header Solution
These are WICKED!! Can not wait tell my set go onto my truck
#17 | |
Re: Header Solution
As a side question is the clutch linkage problem typical of all headers? |
#18 |
Active Member
Re: Header Solution
No they won't work on manual transmission. The problem is to keep them above the frame it won't fit with the manual factory clutch linkage.
#19 |
Active Member
Re: Header Solution
BB Headers coated will be $925.00 with chromex coating.
#20 | |
Re: Header Solution
![]() Any plans to make a set for the 3 pedal crowd? Last edited by lakeroadster; 04-08-2011 at 05:53 PM. |
#21 |
![]() Join Date: Jul 2005
Re: Header Solution
For these headers I ordered a set for my ole heap . Steve said be here in a week or so. Am looking forward to recieving these and getting them installed. I ordered the 1 3/4 coated headers.
The biggest problem people have, is other people Thou shalt be cool and not hassle ![]() Be a site supporter. ![]() The heart of the wise inclines to the right, but the heart of the fool inclines to the left." Ecclesiastes 10:2 |
#22 |
Re: Header Solution
Awesome, very impressive.
#23 |
Re: Header Solution
One more thing that makes this intriguing to me . Is that these are home grown. I paid ten years ago 610 dolars for Ceramic coated tuned Hookers for a 67 Camaro. The headers have been in side all their lives.In less that 4 years The Cramic has bubbled peeled, rust has come forward and ceramic is flaking off. I do not believe Steve will shanghi a customer with poop quality merchandise. Gotta try the homies one time.Oh I bought these Hookers from Summit!
#24 |
Active Member
Re: Header Solution
Thanks Larry, all headers are top quality and all coating is done by Performance Coatings. I'm Running the same product on my truck.
#25 |
![]() Join Date: Apr 2005
Re: Header Solution
Any idea on clearance problems for AC compressor? edin355
