Wheel/Tire Size
I'm thinking of getting 15x8, 4.25 backspace Cragar's for my 72 C-10 long bed, and would like to run 275/60/15’s all around. Will these fit OK? Anyone know if they will stick out past the wheel wells? Also, I would like to get a 2/4drop at some time down the road. Will this setup also work with that drop?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Wheel/Tire Size
You'll be fine.
Here is my old truck with 15x8 and 4.25 bs on all 4 corners. ![]() ![]() Lowered 4/6 275/60 on back 245/60 on front. If you ran only a 2 inch drop on the front, I think your 275s would clear. The tires will clear on the back no sweat regardless of the drop.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: Wheel/Tire Size
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Wheel/Tire Size
wow, that 275 tire looks bigger than I thought. Does anyone else have any pics of this size tire on our trucks?
Re: Wheel/Tire Size
Here's my truck . I have 15x8.5 tt2's with 275-60-15 firestone indy 500 tires on all four corners . I have (about) 3'' / 5'' lowering kit on this truck . As you can see theres plenty of room and they have never rubbed . The offset is 4.25/4.25 i think . I ordered these out of summit racing catalog and they knew what it needed. Good Luck . Buying a set of wheels that dont fit or look bad sucks . I had a bad experence with a new set of 20'' being the wrong offset and dont want you to go through that . good luck - curt Last edited by suttoncurt; 12-16-2008 at 11:06 PM. |
Re: Wheel/Tire Size
This pict shows the fender well better the shadow of the other pict makes it hard to tell where the tire stops and the inner fender begins . I know this setup will work for your truck . curt |
#7 | |
Re: Wheel/Tire Size
Re: Wheel/Tire Size
TX those old school Cragars look good! Very period correct.
'71 C-10 with 5.3 LS2 cam & NWC T5 - Patina King! '83 Jeep Cherokee w 5.3 LS9 cam & SM465 NP208 swap in progress '92 Volvo 960 wagon w 5.3 LS7 cam & WC T5 swap in progress '79 Porsche 911 SC '48 Spartan Mansion 30' travel trailer '10 Porsche Cayenne S - Daily |
Re: Wheel/Tire Size
No , these wheels were not special order . There were ordered out of the summit racing catalog. Wish i was home i would measure for you but im 8 hours from home right now.
