![]() Join Date: Aug 2008
Going to get it next week!!
Well I found me something to tinker on, my plans are to make a daily driver out of it. Looks like someone decided to put a 1980 or so bed on it, the engine is a 350 or 400, the PO thinks it is a 400 hooked to a 350 trans. The normal on the rust areas. He is taking the carb, intake, and distributor. I want to put a short fleet on it and I will prime until I decide what flavor I want it. So what do ya'll think for $600. I will go get it when I finally get away from work next week.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
Old member
Re: Going to get it next week!!
For $600.00 you did good. For a daily driver that's even better! I have seen worse turn out to be show winner's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Looks like a good deal. The 400's have either one more or one less freeze plug than the other small blocks on the side of the block I believe. Others on here may know more, but thats one easy way to tell a 400. Enjoy the project!
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Droppin' It Like It's Hot!
Not a bad score at all! Good looking GMC!
Robert
Life Member RIP CAROL JANICE HARTMAN. BELOVED MOTHER. 01/04/53 - 03/05/09 1969 ![]() Norwood, MO 2007 Big Sandy, TN 2008 Had nothing to do with the forklift! Kirkwood, MO (Midwest Meet 2009) Midwest All Truck Nationals, KCMO - 2008 - 2009 - 2010 - 2012 - 2014 SUPPORT THE SITE HERE! |
Resident of Here
Not bad for $600!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Restoring a 68 SWB
Congrats. Looks like a solid truck for $600.
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
Thanks guys, I can't wait to get her home and start coming up with a game plan on what to do first. It's gonna be a blast. I will post some pics in an album on my home page.
dazed and confused
great start well worth the money
Maybe someday will come
very good deal for a shortbed
good deal... make him leave the carb intake and dist and it will be a great deal. I would of bought it.
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
the 400s have 3 freeze out plugs on the side of the block
Sierra Grande Club
Nice truck and its got the
![]() I'm thinking there's issues putting a short fleet on a step side though. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 01-13-2009 at 09:17 PM. |
So does this look like a 350 then? I will run the casting numbers when I finally get the truck.
S/T, what issues have you heard with doing this swap? Thanks man!!
#15 |
Looks like a really good truck for t5he money
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#16 |
Sierra Grande Club
IIRC it's the frame difference between the two. I'm sure someone with more knowledge in this area will say for sure.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
#17 |
I think the bed and sides are the same as earlier, but the fenders (and bolt holes) are different. I think the stepside fenders are getting pricey, but can't be sure.
Looks like the price is right, but beware... Plan on the motor not being a 400. These are often 305 motors, people lie. A 350 would be good... Go to mortec.com, print out some numbers and look at the block casting numbers to see what you have there. Check out the trans. Its probably not too bad an option, but it could be a PG, which you don't want more than likely. I think a PG has a square pan? A sort of square trans pan with a notch is likely a 350. One shaped sort of like Ohio is a 400. A 700 or 400 trans could look like one of the above, but I don't look much these days. A carb (new), intake and dist will double the price with your labor to install. Used will work if you can find a carb to rebuild or have one. I don't want to be gloomy, just realistic... The question is, is it worth it to you to put another motor and/or trans in it as well as what it needs? I have way more in mine, so I'm just jealous I guess ![]() Last edited by 72lb4x4; 01-14-2009 at 01:04 AM. |
#18 | |
#19 |
man y cant i find one for 600$ !!!!!!! it would be hugger orange the first weekend i owned it (already got paint) and i would just drive it....... as for changing to a short fleet...ur on the right track with that idea IMHO (stepsides ----- ICK)
#20 |
![]() Join Date: Nov 2003
There are no frame differences on a step side vs fleet side. The factory put the same frames under the 2wd short beds, whether they were step sides or fleets.
It's basically as easy as unbolting and removing the step side bed and then setting the fleetside bed down and bolting it up.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#21 |
Gone to greener pastures
![]() Join Date: May 2007
I'd roll in that in a heartbeat.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#22 |
Tot Roddin'
Looks like a nice buy for $600.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#23 |
even if it is a 350 or 305 you got a good deal. why not keep it a stepper? buy aftermarket fenders so the wheel arches look right i personally prefer steppers to be a little different. and hugger orange again do be a little dif
#24 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
The balancer is different on a 350 than a 400. You cant always tell by the freeze plugs. I have a 400 and a 350 and they have the same # of freeze plugs on each side. Some 400s had a different # but not all of them.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#25 | |
I wish I was a cowboy
![]() Join Date: Apr 2008
I wish I could find that truck for $600...even with the rust and engine/trans stuff, it's a good deal. Absolutely stupendous deal for anyone in the North or East...
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
