Old 02-06-2009, 11:50 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
some ?carberator? problems..
when i mash the gas pedal, the truck stutters for a second or two before it catches and keeps goin again...whats wrong with it? Sorry about the stupidity, still learning here.....
THANKS!
(this ? was in another thread but figured id get more responses by putting it in a thread of its own..)
John
1999 Toyota Tacoma 4x4
Old 02-06-2009, 11:56 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: some ?carberator? problems..
what carb do you have? Are you talking about the truck in your signature? Could be any number of things, I would start with checking fuel flow (filters, etc.). details would depend on the details! If it is a quadrajet and the filter(s) are clean, I would start by setting the wind-up spring tension on the secondaries to about 7/8th turn after it contacts the butterfly. If the secondaries open too soon, it'll cause it to bog.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 02-07-2009, 12:53 AM   #3
72chevyk10
I built it
72chevyk10's Avatar
i have that problem sometimes too. i kinda fixed it by puting it up to 12' timing but it still kinda does it. i got a edelbrock 1411 (big block economy version) could it be runin rich/lean?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 02-07-2009, 10:29 AM   #4
oldblue1968chevy
its a quadrajet. 4barrel
i'll check the filters in a lil bit i just woke up leme eat something first lol
^^you lost me there,please explain a lil more please thank you much!
how do i adjust my carberator settings?
rich/lean
idle?
thanks!
John
Old 02-07-2009, 01:43 PM   #5
Pont406
Good carb. Loose allen screw about one turn and set the spring tension. If it's still doing then it's probablly a check ball for accelerator pump is not sitting right.
Pont406 is offline   Reply With Quote
Old 02-07-2009, 03:45 PM   #6
oldblue1968chevy
okay,i looked for the allen screw, couldnt find it, about to check the filters.
accelerator pump, what exactly is that.
point 406 im goin back outside to 70* weather to keep lookin!
John
Old 02-07-2009, 06:33 PM   #7
Pont406
Ok, block choke open. With the engine off look inside the carb and open the throttle. You should see a steady spray of fuel.
