Old 03-17-2009, 04:55 PM   #1
yellowblazer1969
yellowblazer1969's Avatar
Dim left headlight not the bulb help again please.
Just noticed the left headlight is dim hooked up another one and same thing, the driverside is normal i have no ideas. Painless harness installed about 5 years ago, checked the fuses but no dice. just got the truck back on the road from a new engine install, could this be a wiring problem with the light harness?
thanks
yellowblazer1969 is offline   Reply With Quote
Old 03-17-2009, 05:00 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Dim left headlight not the bulb help again please.
most likely it is a faulty ground. No clue where the aftermarket one grounds, but follow the pigtail to where it bolts to something (coresupport if it is like the original), unbolt it and clean/sand the metal. Reconnect it and see if that fixes it.
It's getting power, we know this becouse it lights up. But the power must have a good ground.
Old 03-17-2009, 05:20 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Check your ground!!
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 03-17-2009, 05:25 PM   #4
cparman
sharp as a marble
the 3 wire connector that attaches to the headlight SHOULD have a light green, black, and brown wire. If so, and if it is a painless harness, they will be marked every 5 inches or so. They will say high beam head lamp, ground, low beam head lamp. I would pull the headlight and see if the wiring is marked as I describe. If so, I would think the black will say ground, and be grounded to the radiator support close to the headlights. Just worked on a 50 Chevy with painless wiring and this is what I found.
cparman is offline   Reply With Quote
Old 03-17-2009, 06:02 PM   #5
yellowblazer1969
Smile Re: Dim left headlight not the bulb help again please.
Found it!! yall were right, the ground was loose at the firewall. The truck has been sitting for a while untill recently so i expect i will have plenty more questions as i continue to revive her.
thanks, again
Old 03-17-2009, 07:13 PM   #6
LONGHAIR
Man, I sure wish they were all that easy.............
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
