04-06-2009, 11:06 PM | #1 |
need help?
OK I have a 67 and it HAD manual steering (before it crap out on me). I need to know this i got the power steering box and pump out of a 87 K5 blazer. I was trying to put it in and it looks like i have to more work to make that fit. Or is there a other year the i can use with out cutting up some things? I all ready made the bracket to mount it. will post some pics soon.
04-07-2009, 11:17 AM | #2 |
Re: need help?
i don't think 1967 trucks came with power steering as an option and becuase of that the did not have an indent in the frame that is required to mount a PS box. I think the PS boxes have a little more "bulge" in them. I've seen people use small spacers to move the box about 1/2 inch away from the frame and i've seen people take a torch to the frame to form the indent. Not sure which route is safer. An 87 box should have the same basic bolt pattern.
04-07-2009, 11:25 AM | #3 |
Re: need help?
67's had a completely different kind of power steering and the original style is like finding hens teeth. you can make the power steering gear box work without much trouble. if you have a set of acetylene torches or acess to them you can heat the area where the indent needs to be and hit it with a hammer. i've done it before and it's works no problem.
(Only) Member of the CPNE Fan Club Aint that the truth 67 C-10 350 with 3-speed tranny and 308 gears swb step 82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine) 72 Chevy K20 Suburban (future project) 70 Chevy K20 now 68 GMC K2500 2003 Chevy 2500hd ccsb 4X4 (daily driver) |
04-12-2009, 01:14 AM | #4 |
Re: need help?
will i did some thinking and fab up a plate with spacer's in it and weld it together. going to try to make it work for me. I hope that i don't have to box in the frame with the tire size that is on the truck. has anyone had to do this?
