12-30-2002, 05:51 AM | #1 |
GYRO GEARLOOSE
Help with 3/4 ton rear axle
I just fried my rear axle in my 68 C-20, (4 bolts holding the pumpkin in were missing!) Ran it dry, and ate the pinion gear. Can someone tell me if it is a Dana or Eaton, and what should I do to get it rebuilt or should I hit the junkyards? I just put this in 4 months ago after losing my 4.56, this one is a 4.10, and I would like to go higher, maybe 3.73. I think the bearings are still good. What is the typical cost to have one rebuilt?
Nevada City, CA Everett, Washington 57 3/4 rat, 235, 3spd 66 C-10 Panel, SWB. 350 from '68, 200R4 tranny, 3.07 rear ratio, restoring 68 C10 LWB 350 4spd, 4.56 rear dump runner 82 Camaro, 305, THM-200-R4 84 Monte Carlo 305 TH350, land tuna 85 Tercel SW, snow runner DISGRACED OUTLAW MEMBER OF THE DRUM BRAKE CLUB |
12-30-2002, 09:16 AM | #2 |
"Ochre Ogre"
Because you can drop it out like that it is an Eaton. 4.10 is the best you can do unless you buy new gears. They make a 3.90 for it. Somebody on the board did this. If I remember right, it was over a $1000 to do! It would be worth the time to find a 14 bolt and change it over to fit your truck. I think 3.73's are pretty common.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
12-30-2002, 01:31 PM | #3 |
Cobalt is the one who put 3.90s in his Eaton. And it was pretty expensive. Parts for these rear ends aren't cheap. Might I suggest you hit the junkyards in search of a Dana 60? You could find them with 3.54s, and if you really want 3.73s you can buy those for a D60, too. (But that ratio didn't come in D60s in these trucks.)
The Eaton is a far tougher rear end, and might be worth a rebuild if you need it, but the Dana is no slouch. Good luck.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
12-30-2002, 04:25 PM | #4 |
Yep, that was me.
I had 4.10 gears with a perfect ring and pinion, but the spiders were destroyed and the carrier bearings were shot. I got new 3.90s, and had a detroit locker put in (spiders and eaton posi aren't made any more unless you can find them used and in good shape). Here's the break-down: Carrier Bearings - $500 (they're monsters) Detroit locker - $550 3.90s - $300 new Labor - $250 ------------------ Total - $1600 There's no point in replacing the ring and pinion without replacing the carrier bearings. Chances are they're in bad shape anyway, so you're looking at least $800 + however much you want to spend on a ring and pinion set. My 4.10 gears are still in good shape with a good wear pattern and no chipping, and are sitting on my shelf since I had this done over a year ago. I'll give them to you for $75 if you want them.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
