Old 05-22-2009, 06:51 PM   #1
Rollinsqrbdy
Rollinsqrbdy's Avatar
Exclamation need more Lift and got hub problems
Hello everybody its been awhile i've posted. I got a 84 short wide with a 6" lift and 35" tires but i want a lil more. Whats ya'lls opinion on adding a 3" body lift? Is their anything else I got to do to pull this off? The truck is a half ton. Also when i would lock up the front hubs they would make an awful snd, like a grinding sound like something was broken. So I replaced them but still do the same. What do u think is wrong? Any info would be greatly appreciated.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 05-22-2009, 07:12 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: need more Lift and got hub problems
A body lift is the cheapest way to get a few more inches of lift. The only complaint is the bumper gaps. As for the hubs, its not the hubs. Have you pulled the cover off the diff to inspect that? If not I would do that before throwing any more money at it. Also what did the old hubs look like when you pulled them off.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 05-22-2009, 07:33 PM   #3
LONGHAIR
The "hub" problem is more likely a spider gear issue or an axle joint issue. Closer inspection is required.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-23-2009, 12:23 AM   #4
Rollinsqrbdy
The hubs didnt look to bad. I really didnt pay alot of attention to em. Im just gonna have to jump under the ol girl i guess. I dont know a whole lot bout 4x4's. All i know is that i love em.
New Mexico Member
Old 05-22-2009, 08:49 PM   #5
72 CustomCamper
huh ???
72 CustomCamper's Avatar
With a body lift, if the truck is an automatic, you'll have to lengthen the **** rod from teh column to the trans. If the truck is a stick shift, you'll have to lengthen the clultch rod from the petal to the zbar. Also you'll have to lower the radiator or cut the bottom out of the fan shroud. Sometimes the steering shaft from the column to the steering box will need a little work too...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 05-23-2009, 07:27 AM   #6
Yukon Jack
Yukon Jack's Avatar
Also probably need to extend your fuel filler hose and keep an eye other rubber lines as you raise the body if you go with the body lift. They are cheap but fairly involved to install.
What is your intended use of this vehicle?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-23-2009, 09:44 PM   #7
Rollinsqrbdy
yukonjack- Thanks for the info. Im wanting to start workin on the ol truck pretty soon. This room has been real helpful and is full of alot of greaty people
New Mexico Member
