Old 07-20-2009, 11:10 AM   #1
wahlie
HOW do you remove spindles and control arms
Ok folks,
I've scoured the site here on how to remove my front spindles. I've got the cotter pins removed, and bolts loosened. I've read that guys are hitting the ball joints with a hammer... I tried this but she's not budging. I also read that guys are jacking the lower control arm to create pressure.... tried that as well.... no dice.... I forgot to snap a pict this morning of where i'm at in the process but I need to get these spindles off so I can eventually get to my control arms, get them off, sandblast,powdercoat them... I'm putting new ECE spindles on btw so I don't need the old ones.
Thanks,
Chris
wahlie is offline   Reply With Quote
Old 07-20-2009, 11:15 AM   #2
67chevemall
67chevemall's Avatar
Re: HOW do you remove spindles and control arms
You need a fork chisel or wammee bar to pop them up.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-20-2009, 11:34 AM   #3
xplicitlyricky
xplicitlyricky's Avatar
That shoulod do it. I used a large, large pry bar aswell, but it was not the safe way to do it. A fork chisel and air hammer is the quickest, under 20 bucks at Harbor Fraight.
LIVE TO RACE!! DIE TO WIN!!!
xplicitlyricky is offline   Reply With Quote
Old 07-20-2009, 11:37 AM   #4
71tahoe
71tahoe's Avatar
Have you been hitting the bolt end or the other end. A pickle fork does work but you may have to wedge it in there and also whack it a few times if you plan on replacing the ball joints anyway.
71tahoe is offline   Reply With Quote
Old 07-20-2009, 11:50 AM   #5
americanmusc1e
americanmusc1e's Avatar
go pick up a Haynes shop manual for your truck, it shows you how to make a tool that will pop the ball joints loose!!! or you can rent a fork from Oreillys for free!!!!!
but you really should have a shop manual of some sort anyway!!!!!!!!
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 07-20-2009, 12:00 PM   #6
wahlie
Thanks for the tips guys. I've got the haynes manual as well as the assembly manuals/shop manuals.... I didn't think to look in the haynes but scoured the other too... I've been hitting the spindle itself... Do I want to whack the actual ball joints or the top and bottom of the spindle?
Old 07-20-2009, 12:08 PM   #7
vegaschevy
you really need to go to your local auto zone, checker, or oreillys, or anywhere that rents tools at no charge. You want to get a pickle fork to go inbetween the bottom of the joint your separating and the arm. hammer it in and sometimes screw the nut back on the end and whack it gently and the fork pressure will allow it to pop off.
vegaschevy is offline   Reply With Quote
Old 07-20-2009, 03:18 PM   #8
see ten
WTB this ad
see ten's Avatar
A hammer and the force of the spring should suffice. See if these vids help you any.
http://www.67-72chevytrucks.com/vboa...ight=worthless
see ten is offline   Reply With Quote
Old 07-20-2009, 03:46 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
A BFH is all I've ever used.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 07-20-2009, 03:52 PM   #10
Elephanthead
A pickle fork is 3 bucks at harbor freight.
Elephanthead is offline   Reply With Quote
Old 07-20-2009, 04:33 PM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
Replacing ball joints= PICKLE FORK
Reusing original ball joints= BFH
A pickle fork will tear the ball joint rubber grease boots. Don't use it unless you plan to change ball joints.
Keith
Convert to disc brakes.
Old 07-20-2009, 06:41 PM   #12
LONGHAIR
It's funny how the places that will "rent" you the tool are also the ones who will sell you the ball-joints when you tear them up.....LOL
I don't use a pickle fork ever.....Don't even own one. If you have one that is really bad, hold another hammer against the opposite side of the spindle when you strike it. Don't swing the second hammer, just hold it against the side of the spindle near the ball-joint stud.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-09-2009, 06:16 PM   #13
john
member #16
john's Avatar
This is good advice. The second backup hammer helps distort the taper to pop the ball joint loose.
john is offline   Reply With Quote
Old 07-21-2009, 09:22 AM   #14
71tahoe
71tahoe's Avatar
Advance Auto and some others have a HELP section. They sell replacement grease boots. I'm sure NAPA carries them too.
Old 07-20-2009, 04:48 PM   #15
wahlie
excellent... gonna grab a pickle fork tonight. Thanks guys. I rewatched that tutorial for the 20th time that someone posted and something clicked. Also found some stuff on ehow.com
Thanks,
Chris
Old 07-20-2009, 06:20 PM   #16
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Whack the top and bottom of the spindle itself.Right on the outside of the ball joint.If you're using a 3 # hammer you will need a bigger hammer.I use a 5 # engineers hammer.I had to whack the crap out of the passenger side to get it loose.The drivers popped both joints loose on the third whack.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-20-2009, 09:26 PM   #17
wahlie
mission control...... we have liftoff... thanks for the tips guys... the pickle fork worked wonders. thanks for all of the tips. I even got the upper control arm off. gonna try to salvage the arms with a little sandblasting and powdercoating.
-Chris
Old 07-21-2009, 02:27 AM   #18
Super-Dave
Super-Dave's Avatar
I would replace the ball joints while you are there, I did my own, just drill the upper rivets, and press the lower ones out.
Super-Dave is offline   Reply With Quote
Old 07-21-2009, 09:27 AM   #19
wahlie
yup, i'm going to redo the entire suspension plus press out the old ball joints...
Old 10-09-2009, 10:37 AM   #20
patthethird
I have a 3/4 ton 67 I'm trying to get the ball joints off of. I had a hydrolic jack in between the a arms and was beating a pickle fork to death with a 5# hammer. I swear I'm not getting anywhere. I dont know what i expect y'all to say, I am just frustrated.
patthethird is offline   Reply With Quote
Old 10-09-2009, 11:16 AM   #21
71tahoe
71tahoe's Avatar
I just did my half ton and all it needed was the spring pressure. Tried smacking the ball joint with the nut backed off with no luck. Then tried air hammer with a pickle fork with no luck. Got the BFH on the pickle fork and bingo. The only problem was getting the mangled nut off the ball joint. Grinder with a cutoff wheel made short work of that.
Try alternating hitting the pickle fork and the ball joint stud/nut.
Also make sure your assembly can't just fly apart. Keeping the nut on the ball joint should prevent it but it's a good idea to chain the spring to part of the chassis too.
Old 10-09-2009, 01:27 PM   #22
LONGHAIR
Originally Posted by 71tahoe View Post
The only problem was getting the mangled nut off the ball joint. Try alternating hitting the pickle fork and the ball joint stud/nut. Also make sure your assembly can't just fly apart. Keeping the nut on the ball joint should prevent it
You shouldn't be mangling the nut.....You don't hit the nut/stud. You hit the spindle on the side, right where the tapered part of the shaft goes through. The "shock" of the hit makes it "jump" apart.
This is not the correct spindle, but the arrow shows where to hit.
Old 10-09-2009, 02:31 PM   #23
71tahoe
71tahoe's Avatar
Much better advice. Less aggravation = happier camper and you can reuse the ball joints. Mine were shot so no loss but I really need to remember this for next time. Thanks LONGHAIR.
Old 10-09-2009, 06:00 PM   #24
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I must be a puss or some thing. I've been whacking them all week while I was on vacation. And it has not worked out so well. I spayed WD-40 on them, used a pickle fork, and a BFH. But no luck. I guess I need a BIGGER FH. I'll put on my man pants and try it again.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 10-09-2009, 07:12 PM   #25
lolife99
lolife99's Avatar
Removing the tie rod end from the spindle will also get you a little more "swing room" for the hammer.
Keith
