700R4 Question
I have a 71 GMC 4x4 with a th350. How hard would it be to put in a 700R4? I have a 205 trans. case
[IMG]http://mustangmods.com/publish/topless99/truck2.jpg[IMG] Last edited by 71GMC 4x4; 01-07-2003 at 04:40 PM. |
Workaholic
Ask the guys at http://www.700r4.com
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
It is a fairly simple exchange. I did it in my stepside. You just need to make sure that you put in a shortened trans shaft which is available from Advance Adapters. It will then bolt right up to your TH350/205 adapter.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
What about the crossmember, did you have to move it?
[IMG]http://mustangmods.com/publish/topless99/truck2.jpg[IMG] |
Yes, I did have to move the crossmember. I did a few changes at once so I knew that I would have to move it. I put in a BBC and moved the engine crossmember forward to move the distributor away from the firewall. I also changed from a rockwell TC to a 205. It is easy to move and redrill the TC crossmember. The hardest part is figuring out where to drill the holes for the TC stabilizing mount on the passenger side.
