08-16-2009, 08:11 PM | #1 |
differential overflow hose question -
Does anyone know if this hose on the diff is suppose to pull off, or is there a clamp? I can't tell and I don't want to screw it up by pulling too hard.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-16-2009, 08:14 PM | #2 |
Formerly- 1972SuperCheyenne
Re: differential overflow hose question -
There is a clamp. The hose is actually a vent and not an overflow.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
08-16-2009, 09:45 PM | #3 |
Just had mine off, mub dobers had it plugged real good. It pulled off even with the clamp in place as the original rubber was hard as a rock, the hose fell to pieces when I tried to clean it out. I replaced mine with about 2.5 feet of 5/16" fuel tubing.
08-16-2009, 10:12 PM | #4 |
My bad, overflow. Is the clamp the kind you pinch together with pliers or a screw type?
08-16-2009, 10:19 PM | #5 |
Never Ending Projects
If stock, I believe it's the pinch type... well at least the two rear ends I worked with were.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-17-2009, 04:19 PM | #6 |
The clamp is a pinch type and if you are wanting to restore the original color was a creamy yellow. In order to be absolutely correct there is also a vent installed in the end of the hose (really a one way check valve to prevent mud duabbers and other things from getting into the housing.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
