09-22-2009, 10:33 PM | #1 |
Location: phoenix AZ,NOW ON THE DIRTY EAST SIDE IN THE MIDDLE OF THE BAD WEST AND THR RICHICHY SCOTTSDALE
down shift
what would cause my truck not to down shift i have 350 motor th350 tranny in a 1976 gmc pickup longbed it feels like im pressing on the brake slowly anyone know
you know who i be |
09-22-2009, 11:10 PM | #2 |
Happy to be here
Re: down shift
Will it shift up by itself? Will it downshift if you do it manually?
09-22-2009, 11:20 PM | #3 |
Re: down shift
yeah itll shift up yes i can do it manually what gives
you know who i be |
09-23-2009, 01:10 AM | #4 |
Re: down shift
k riddle me this what happens if my drive shaft isnt all the way into my tail shaft of my transmission
you know who i be |
09-23-2009, 01:12 AM | #5 |
At the body shop.
Re: down shift
The easy fix would be the kickdown cable is off/out of adjustment and the driveshaft should be out an inch or so on slipyoke
09-23-2009, 01:17 AM | #6 |
Gettin It One Pice At A Time
Re: down shift
I don't think the kick down is for down shifting like the problem he is having. IIRC it is to make it drop down to 2nd gear to help you pass some one or accelerator faster when WOT.
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
09-23-2009, 01:45 AM | #7 |
Re: down shift
how do u adjust the kick down if this is the problem but my shaft was out to where it was leaking fluid out of shaft it was leaking like crazy
you know who i be |
09-24-2009, 11:28 AM | #8 | |
a fool with no money
Re: down shift
as they stated... need to know whether it's not kicking down on acceleration, or it's not down shifting when roll ing to a stop.
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
09-23-2009, 08:20 PM | #9 |
Re: down shift
Drop down - down shift, ummm same thing. If the detent cable is not properly adjusted it will not "Down Shift - Drop Down". It was never stated which gear this problem happens in.
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
09-23-2009, 08:25 PM | #10 |
Re: down shift
09-23-2009, 02:09 AM | #11 |
Re: down shift
first, did you check to make sure all the vacuum lines to the trans were in good shape?
09-24-2009, 01:15 AM | #12 |
Re: down shift
I thought that there was a difference. one is for passing and accelerating using the detent cable. you mash down on the go-pedal and it pulls on the cable and makes the trans drop down to 2nd. the other is when you are coming to a stop or let off the accelerator *cable is then slack or no tension on it*. and the trans will start to down shift eventually by its self. without even using the Detent cable. and the later is what I gather is his problem..?
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 09-24-2009 at 01:16 AM. |
09-26-2009, 11:28 PM | #13 |
Re: down shift
Any word?
09-29-2009, 10:25 PM | #14 |
Re: down shift
what if i run with out dent cable the leak is coming from the u joint close to trans of the two piece drive shaft wants going on hear
you know who i be Last edited by supamatic; 10-18-2009 at 02:22 AM. |
09-29-2009, 11:04 PM | #15 |
Re: down shift
it is not advised. it will shorten your trans life. for us to help, can you tell us When it does not down shift?
09-29-2009, 11:46 PM | #16 |
Re: down shift
it does it when im at 50 55 60 thats third anit it i let off gas pedal it like if i slowly press the brake but im not no gluide it doesnt come to a stop just slows down fast
you know who i be Last edited by supamatic; 09-29-2009 at 11:46 PM. |
09-30-2009, 01:30 AM | #17 |
Re: down shift
I have the same thing happen to me. I always thought that's how its suppose to be. its kinda like when you down shift to help slow down. I always took that as compression braking. what you could do is when you are in free way speed and am in 3rd gear. mash it down, it "should" drop down to 2nd gear. if it does not then your cable is out of adjustment. when you are coming to a stop and you hear it shift from 3rd to 2nd to 1st then that is normal. then I would say it is OK. I would also wait to see if someone can confirm that.
09-30-2009, 07:37 PM | #18 |
Re: down shift
Sounds good to me
09-30-2009, 11:51 PM | #19 |
Re: down shift
thanks that sounds good it makes sense could it be i have it hooked wrong inside trans and its sticken inside oh yeah how do i adjust it or whatever
you know who i be Last edited by supamatic; 10-01-2009 at 12:07 AM. |
