Old 10-26-2009, 04:34 PM   #1
koolky
67-72 Addicted
koolky's Avatar
Removing Dana Pitman arm
what is the proper way to remove the pitman arm? Ive got 2 D44 and i cant get them off! I removed the nuts... and got 2 of the tapperd things out. Ive tried penatrating oil and heat, hammer and air chissel.w
'72 K20
koolky is offline   Reply With Quote
Old 10-26-2009, 07:36 PM   #2
LONGHAIR
Re: Removing Dana Pitman arm
Hammering is really the only way. Usually by the time you have 2 of them out, it gets easier....
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-27-2009, 06:26 AM   #3
Blazer1970
Blazer1970's Avatar
You are referring to the steering arm. The pitman arm attaches to the steering box. To get the steering arm off, hit it hard, from the side, with a big hammer. What you want to do is to momentarily deform the bolt holes so that the tapered inserts will pop out. Then the steering arm will fall right off.
Blazer1970 is offline   Reply With Quote
Old 10-27-2009, 08:17 AM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Big hammer!!
Hit it down, out on the drag link end.
Then hit it up.
Then hit it sideways.
Cuss.
Soak with penetrant of your choice.
Repeat.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-27-2009, 10:57 AM   #5
For scheduling purposes you can figure it`ll take ya about 3 beers.(or beverage of choice).
Old 10-27-2009, 10:22 PM   #6
koolky
67-72 Addicted
koolky's Avatar
Thanks guys, i figured it would be kinda simple. I moved up to a much bigger hammer and eventualy a wedged punch. Took a little longer than I thought, probably a six pack if i had one lol. The next one I need to remove is on a knuckle that is not attatched to the D44 anymore...
'72 K20
Old 10-28-2009, 07:30 PM   #7
LONGHAIR
I'm sorry....
Old 10-31-2009, 02:39 AM   #8
rennat_2006
rennat_2006's Avatar
hit it from all angles like described above and another trick ive figured out is taking a chisel or a punch and hitting the cone washer where it is split so it turns in the hole in the arm. From what ive seen its always the cones that it is stuck on.
1972 C10 cheyenne super -350/th350 Wifes truck
1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc
2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear.
2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies.
rennat_2006 is offline   Reply With Quote
Old 11-01-2009, 08:49 AM   #9
csa daddy
csa daddy's Avatar
you can try to get something to wedge the cone waser apart
csa daddy is offline   Reply With Quote
