Old 11-12-2009, 09:36 PM   #1
Matt Man
Matt Man's Avatar
crossmember info
ok if i switch my truck to 4wd will i need another crossmember? also would i have to pull the engine to change the crossmember, also is the crossmember welded to the frame?
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-12-2009, 10:21 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: crossmember info
Yes if your truck is 2wd you will have to change it to a 4wd cross member. You don't have to pull the engine, but I can tell you it will be 100x easier to just pull it and get it out of the way. I'm sure you could do it with it jacked up with a cherry picker still hooked to the tranny, but it won't be fun. And the crossmember isn't welded in place, it has rivets that hold it in. You either torch them out, or use a chisel, air chisel, grinder, or cut off wheel to cut the head off. Then you use a punch and knock them out.
Ryan
1969 Chevy milk truck
Old 11-12-2009, 11:37 PM   #3
72 CustomCamper
huh ???
72 CustomCamper's Avatar
The 2wd crossmember is bolted in...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-13-2009, 12:42 AM   #4
Matt Man
Matt Man's Avatar
i will poke around my truck tommorow to see for sure. i just really dont want to pull the engine....
Old 11-13-2009, 07:07 AM   #5
ghettoluxury
ghettoluxury's Avatar
No need the motor mounts will keep it from dropping too far. Just suport the tranny with a floor jack
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-13-2009, 04:07 PM   #6
Dieselwrencher
The motor mount brackets are bolted to the cross member so that is a problem. You have to unbolt the motor mount brackets to get the crossmember out.
Ryan
Old 11-13-2009, 05:42 PM   #7
b454rat
No matter how you get it out, a 4wd crossmember won't bolt in. I tried 2 different ones and neither would go in without trimming. I'm gonna use the stock 2wd mounts and have a crossmember fabbed up after I get the motor ready to go in. I have a tall deck with the huge oil pan, so need to have the motor to get it to fit.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
