Shackle flip kit?
Hey guys i keep hearing bout this kit. Im curious does it work with the 6" exsisting lift? Like if i order a 4" shackle flip kit, will i end up with a 10" lift total? Anyone got any pics of this sit up? Also if it does work together can i put a 3" body on top of that and have a total of 13" of lift? Any info would be greatly appreciated.
Its Kool to be a square ![]() 2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's 1985 C-10 ......My dream truck (under construction) 1984 k 10 Silverado...6" lift with 38.5 super swampers ![]() ![]() --- ![]() ![]() ![]() |
Grease Monkey
Re: Shackle flip kit?
Shackle flip kits do in fact have 4" of lift. So to answer your question if you add a BL on that too you would have about 13" of lift.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Sb 400 club
I went with DIY4x kit on mine. Kurt is an awsome guy and was very helpful ofver the phone. here is a link to his site
http://diy4x.com/cart/index.php?rout...product_id=112 here is some pics of mine. Welds where great and fit was awsome! I went with the 4.5 inch cross tied shackles he offers a longer shackle if you want more lift ![]() ![]() before ![]() after ![]() ![]() ![]() removing the rivits is a real PITA but its worth it ORD also offers the kit on there site (offroad design) they are out of Colorado
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 11-18-2009 at 04:11 AM. |
I see you painted your front perches. Did you also have to remove them? Did they get relocated, front or back?
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
Sb 400 club
No my front perches where rotted. Those are GM replacements in the factory location. The kit does not require there removial!!
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Does the axle move in comparison to the factory location? Does the axle looke centered in the wheel well opening? Did you use the "eazy inch" or whatever it is called to adjust for that?
I thought I remember reading about the axle moving forward with a shackle flip kit but now I cannot find anything. Did the 4.5 shackle help level everything out compared to a 4" front instead of having a slight rearward squat?
Sb 400 club
I talked with Kurt the owner of DIY4X and asked about the movement. He told me it moves the axle approximately 1/4 of an inch forward. I have not noticed it at all. I do have mud flaps mounted on the back wheel openings which might be why? My father also has not noticed the forward movement compared to other truck pictures online. With smaller tires it might have been noticeable
I am not using an ez inch or zero rate. may add one at some point to put alittle rake on it tho. My drive shaft angle is perfect. No Tcase drop was needed It sits level and has a decent shackle angle. I don't have any unloaded bed pictures tho. ![]() BEFORE FRONT LIFT http://s65.photobucket.com/albums/h2...fblower019.jpg ![]() Done lift with 34x10.5's..... It has abot 500 pounds of scrap metal in the bed tho....... ![]()
84 400- I know you got some more pics? It looks real good.
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice! I have always had great luck with the DIY4X crew!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Sb 400 club
I know right alotta pics... But nothing recent. I am back at school so the truck just sits. Hoping to go out wheeling over thanksgiving break tho.
I just hope the pics help to show what the shackle flip is all about and how it works. I did alot of research and talking before lifting mine.
so the front is also lifted with the shackle flip kit rite? Just like the one in the rear? I hope this aint a stupid ?
No I don't believe the front recieved a shackle flip kit. But I could be wrong.
![]() Join Date: Feb 2009
There is no flip for the front. Keep in mind too that the pinion angle caused by the flip may/will necessitate a CV joint coming out of the TC for the rear, or perch rotation.
While you could 'stack' all of the lifts mentioned above, street manors would not be great. Which is fine depending on your goal.
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() Last edited by Oilbrnr; 11-19-2009 at 05:58 PM. |
#14 | |
Sb 400 club
Mine has neaither and my Drive line angle is perfect. That said this is on a SHORTBED. He told me the kit was desgined for K5's originally and was built so pinon angle would be fine. On a long bed you may need to shim some but i am unsure. Keep in mind tho the kit was desgined to work with FACTORY springs not the lift springs ur talking about. Those will changer your pinon angle.
#15 | |
With the OEM rear springs and a zero rate on my K5 the pinon pointed almost DIRECTLY (1-2* negative) at the TC, with the new Tuff Country 2" rears and no zero rates that I just installed last week it is now a straight shot to the TC yoke. This isn't great either, as the rear Spicer now does not have to 'bend' which means grease does not redistribute in the cups. Ideally there should be a 2* negative pinon angle with a CV. None the less, I'd rather deal with greasing the rear U-joint vs. putting up with the vibration and wear/tear on the output section of the NP205. Might want to google 'driveline angle' and do some research and compare/measure your setup. I'd be willing to bet money you have issues. ![]() ![]() ![]()
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() Last edited by Oilbrnr; 11-19-2009 at 08:20 PM. |
#16 |
I have 6" of lift on my truck. 6" BDS springs up front, 4" rear Tuff Country soft rides and a 2.5" shackle flip from ORD. My axle moved forward some, but not sure how much.
When I first put the shackle flip on, I used a 4" block, and had good angle. I swapped the springs, now my shackle is bout straight. Front rides good (weight of the 454 helps) but the rear is stiff do to the angle. One of these days I'll move it forward...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#17 |
The axle will move forward slightly due to geometry.... I can draw it out if needed...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#18 |
Sb 400 club
On the front i am running 4 inch lift springs and ORD HD shackles with greasable poly bushings. These shackles are 1/2 inch longer then stock. This was done to aviod spring contact with the frame... Also the stock front shackles are real weak and often bend when heavily used offroad. That said my front shackle angle IS CRAP.
Also I am running 52 inch long rear springs. IF i swaped to 56's I would gain abetter shackle angle. The best would be chevy 63's but that is a whole other project.
#19 |
Sb 400 club
I am just repeating what he said to me. I do realize he is the manufacturer and you need to take there info with a grain of salt. Maybe it is not a perfect angle but like he said and i have found it works with no vibs My angle is okay and I have no vibes. You do make a good point and I am not going to argue. I don't have any vibs but this is not my daily driver eather. I use my truck to haul junk and the only highway trips it sees are to pickup things and drive to trail runs. I have some pinon shims but they are not installed.
Did you lower your T-case??
#20 |
No I did not lower my TC. I had to rebuild and lengthen both front and rear drive shafts so I bit the bullet and put the CV on the rear at the same time. ~$750
-Don- '66 ![]() '77 ![]() '80 ![]() '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf ![]() |
#21 | |
Sb 400 club
Thanks for your input on pinon angles gave me a better understanding Hopefully this helps others wanting to do the flip
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 11-20-2009 at 06:24 PM. |
