How to adjust rear adjustable Track bar???
What is the simple way of adjusting this bar for centering the axel from side to side??? Any advise helps! I'm using early classic adjustable on air ride suspension with trailing arms??
Re: How to adjust rear adjustable Track bar???
When I replaced my rear suspension I adjusted mine by measuring the distance from the rear inner wheel well to the outer edge of the tire. This was just to get it close enough to drive it too the alignment shop.
Redefining LowBudget
pretty simple..
set your truck to ride height measure from you rim to inner wheel well adjust accordingly I recomend send you truck off to an alignment shop just be sure they DON"T ADJUST YOU AIR...also guages and a sharpy work well....I marked the face (glass) with a red sharpy so you can hit your ride height at a quick glance
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
don't measure to inner wheel well, as sheetmetal can be "tweaked" and is not a fixed point on the frame rails ... measure from wheel to frame rail
Okay, so dont take tires and wheels off, and set back of truck to ride height???
#6 | ||
'69 Chevy SWB
![]() Join Date: Feb 2009
Matt ![]() ![]() ![]() ![]() ![]() '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
thanks!
