07-06-2010, 02:23 AM | #1 |
frame cracked..
Well, the other day my buddy was looking over my truck, turns out the frame is cracked about 5 inch's by the powersteering box, I would have never noticed it as it was behind the box. So time to tear it down... Plan is to strip it all and get it ready to have it repaired. I know a guy that has done many of these
This common on these trucks? Any of you had this happen? Any pictures of the repair?
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
07-06-2010, 02:48 AM | #2 |
Re: frame cracked..
I think it is common on these trucks
My last name is Chiono pronounced key-ono even if my grammar teacher told me Ch dont make a K sound 1995 Ext. cab 350 4wd dd 260,*** miles 1986 1/2 ton swb 305 2wd (melted bearings) SOLD!! 1982 3/4 lwb 6.2 diesel 2wd 1962 Chevy 283 4 speed long step 2wd 2 OWNER GONE!! |
07-06-2010, 06:13 AM | #3 |
Re: frame cracked..
Very common on these trucks. Especially the 4x4 and trucks with wider tires. It's because the pitman arm is on the same side as the steering box and creates too much pressure on the frame near the steering box. If you wanna fix it right and not have to worry about it again, put the crossover steering from like a 91 suburban on it.
Smoke Tires, not Drugs Last edited by MONTEZ; 07-06-2010 at 06:14 AM. |
07-06-2010, 10:36 AM | #4 |
Re: frame cracked..
Very Common... even happened to my 2wd.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
07-06-2010, 10:44 AM | #5 |
Re: frame cracked..
I had this happen on my '79 stepside 2wd. I just ground a grove along the crack with a carbide bit and welded a bead over it and ground it down. back in business, at least I hope
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
07-06-2010, 11:01 AM | #6 |
Re: frame cracked..
You may want to consider welding a plate to the frame, more than likely it will crack again.
Smoke Tires, not Drugs |
07-06-2010, 12:04 PM | #7 |
Re: frame cracked..
It's a common problem with these trucks. Autofab makes a gusset kit to reinforce the frame. Check it out.
http://www.autofab.com/sbgk%20100.htm Good article here. http://www.4wheeloffroad.com/brandpa...ame/index.html
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
07-06-2010, 12:09 PM | #8 |
Chris
Re: frame cracked..
jcwhitney sells a precut and drilled kit that welds back in over the crack.
Personally never had one break, but bought a truck that was 2wd with one already broke. I'd weld the crack up, plate it inside and out and weld the guts out of it all.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
07-06-2010, 12:40 PM | #9 |
Re: frame cracked..
