Old 07-25-2010, 02:01 PM   #1
delta
Front leveling
Searched on here but nothing found. I have an 80 3/4 ton with 4" lift. I have the "chevy slope" and want to level the front with the back. I have all new springs and hardware in it so i really dont want to put different springs in the front. My buddy said hed get me some 1 ton springs but it might ride rougher than it already does now(i hit a dime on the road and i can feel it!) Is there a solution to this?bigger spring shackles? I really only need an inch or inch and a half to level out.
delta is offline   Reply With Quote
Old 07-25-2010, 02:15 PM   #2
Benelli
Watchin the rust grow
Benelli's Avatar
Re: Front leveling
Is it 4wd? If you're just looking to pick up the front end and it is 4wd - Rancho Part # RS86201 or Tuff Country Part # 81200
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 07-25-2010, 07:39 PM   #3
slugish
Slugish
Re: Front leveling
Spacers under your front springs > fit right in your spring cup > most front end , suspension , tire places will have them . definitely the least expensive way to go Iwould think .
slugish is offline   Reply With Quote
Old 07-25-2010, 07:46 PM   #4
cochino12
It followed me home?
cochino12's Avatar
Re: Front leveling
here you go
http://www.offroaddesign.com/catalog/Zero%20Rates.htm
"Since these are a true bolt in leaf, they are safe to use on the front or rear suspension for extra ride height or to relocate the axle. "
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-25-2010, 09:10 PM   #5
Shawn5488
Re: Front leveling
Shave your rear blocks down or put a add-a-leaf in the front, anything you do to the front will make it ride like crap unless you put 6in. lift springs under it.
I would never put blocks under the front end, good way to die!!! They are known for spitting out on turns.
Shawn5488 is offline   Reply With Quote
Old 07-27-2010, 12:14 AM   #6
delta
Re: Front leveling
Thanks guys. i also have another set of heavy 3/4 springs to look at so i'll have to measure them as well.
